Cast front axles
64 replies to this topic
#1 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 01, 2015 - 08:04 AM
Not a good day with puller hooked up and tires didn't grab right away. THEN the front end came up it took off and couldn't stop it before the end of the pad. so I hit the brakes. came down way to hard. Oh well
  • Gtractor, Alc, boyscout862 and 2 others have said thanks
#2 Jazz OFFLINE
Jazz
  • 2,589 Thanks
  • 1,520 posts
Posted August 01, 2015 - 08:15 AM
Thats truly unfortunate. So do you source another cast axle or fabricate a steel axle?
  • Chris11 and boyscout862 have said thanks
#3 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 01, 2015 - 08:16 AM
Ill machine one out of aluminum.
#4 olcowhand ONLINE
  • 42,433 Thanks
  • 31,812 posts
Posted August 01, 2015 - 08:22 AM
Wow...you did come down HARD!
  • Chris11 said thank you
#5 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 01, 2015 - 08:28 AM
VERY
#6 Marty'70 ONLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 866 Thanks
  • 721 posts
Posted August 01, 2015 - 09:59 AM
Nice day for pulling, too bad about your luck. Hope you get it back on the track asap.
#7 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 01, 2015 - 10:13 AM
I'll have one made up be for next week.
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted August 01, 2015 - 10:26 AM
OUCH!
#9 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,089 Thanks
  • 590 posts
Posted August 01, 2015 - 11:16 AM
Did you loose any teeth? Must have really slammed.
#10 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,886 Thanks
  • 10,050 posts
Posted August 01, 2015 - 11:34 AM
What's the bend strength of aluminum?
#11 EricFromPa ONLINE
EricFromPa
  • 3,992 Thanks
  • 3,257 posts
Posted August 01, 2015 - 12:37 PM
Thinking I would make one out of Steel.Either 2x3 or 2x4 or solid Steel.But you want Some weight on the front.With an aluminum axle you will tear the welds out.They don't bend but will Flex a bit.
I've seen alot of pullers use these axles.Just bolt it fast you don't need it to pivot.
That gives me nightmares lol.
My story :(
I just got my 149 back together after installing a fresh rebuilt ported pump and hydro lift cylinder and the whole 9 yards (mine came factory with manual lift) and new driveshaft couplers and pins.I took it for a short ride.Must not of had the linkage adjusted correctly on the tranny.Note I had the heavy hood and cast grill off of the tractor so no weight on the front.
I bumped it into reverse then bumped it forward but it went WAY to far forward.It came straight up and back down Super hard.Busted the axle on the left side tore the carb off,smashed the air cleaner and cracked the oil pan.I was used to the non ported pumps normally they will bog the engine down or spin tire.This thing came up and stayed straight up in the air and tossed me off of the seat.
I now respect the ported pumps :rolling:  Those old Cast axles snap Way to easily btw.I would rather have one that bends than one that snaps like a trig.
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted August 01, 2015 - 01:52 PM
My father-in-law told me about being asked to settle a disagreement between a couple of friends.
They were building a Super Modified car to race in Knoxville, Ia.
One wanted to harden the tie-rod ends and the other wanted them tempered so they would bend instead of break.
Naturally John said they should bend.
Incidentally that car, a 4 door model A FOrd with the front doors cut out and a Buick NAILHEAD is on display in the National Sprint Car Halll of Fame Museum next to the track. It was pretty successful till the Sprint Cars came on the scene, and took the unlimited modifieds out of the picture.
Edited by JD DANNELS, August 01, 2015 - 01:54 PM.
  • MH81 and Chris11 have said thanks
#13 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted August 01, 2015 - 03:36 PM
I could make one out of chrome molly steel
#14 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,886 Thanks
  • 10,050 posts
Posted August 01, 2015 - 08:25 PM
That sounds more like it.
#15 jabelman OFFLINE
jabelman
  • 2,238 Thanks
  • 1,600 posts
Posted August 01, 2015 - 08:39 PM
Just curious what was the cast off of?
