L-12 front end loader hydraulic oil
5 replies to this topic
#1 luis gonzalez OFFLINE
luis gonzalez
  • 2 Thanks
  • 9 posts
Posted July 30, 2015 - 11:46 AM
Do any you out there know what type of hydraulic fluid to use an a L-12 front end loader ?
#2 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted July 30, 2015 - 12:00 PM
http://simpletractor.../l-12_specs.htm
here's some specifications for it but not what type oil. tells you how much it needs tho.
  • luis gonzalez said thank you
#3 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted July 30, 2015 - 12:13 PM
SAE30 was spec...I use 10W30. Same as hydraulic lift used on these tractors.
#4 luis gonzalez OFFLINE
luis gonzalez
  • 2 Thanks
  • 9 posts
Posted July 30, 2015 - 12:38 PM
Thank you guys is it SAE10w30 motor oil and you where right talntedmrgreen it takes a breather on the top of the hydraulic tank i still getting oil out from there when i lower the bucket so im thinking i got the wrong oil i was using john deer hydraulic oil is foaming a lot when it returns to the tank thank you for all your help !
  • VintageIronCollector said thank you
#5 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted July 30, 2015 - 01:12 PM
Foam is deifintely the enemy...will make a mess and your pump will cavitate and wear prematurely.
#6 KennyP OFFLINE
  • 38,296 Thanks
  • 45,895 posts
Posted July 30, 2015 - 06:10 PM
Foam means you have air getting into the system!
