I have a case 220 hydrolic question...
8 replies to this topic
#1 Slaminbrews OFFLINE
Slaminbrews
  • 24 Thanks
  • 21 posts
Posted July 29, 2015 - 08:17 PM
I have a case 220 with a 12hp Kohler engine... With hydro lift blade/deck. Anyways I'm thinking about building a small log splitter and was wondering if there was any way to run the hydrolic ram/cylinder off of the mower hydrolic pump? Anybody know the gpm on them? Or if it's even possible? Thanks
#2 boyscout862 OFFLINE
  • 13,449 Thanks
  • 9,394 posts
Posted July 29, 2015 - 10:07 PM
Yes. I saw one 35years ago. I think that it used the same hydraulics as the tiller. Good Luck, Rick
#3 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted July 30, 2015 - 07:32 AM
Case and Ingersoll still make splitters for these.  They run off the rear pto like Rick said.  tow behind or 3pth.  Single or double action.  They are hard to find $$$ might could make your own.  Pump flows 10gpm you should get all the fluid out of the splitter so it don't bung your drive oil.
Personally for less money i'd buy an old tow behind with its own motor save wear and tear on your Kohler and a lot less work probly run faster too, good luck
#4 Slaminbrews OFFLINE
Slaminbrews
  • 24 Thanks
  • 21 posts
Posted July 30, 2015 - 05:20 PM
I think I'm going to try to disconnect the hydrolic lift cylinder and put quick connects on and try to run it that way. It's all free so it's worth a try.
#5 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted July 30, 2015 - 06:57 PM
Bad idea. You would be much, much better off getting a hydraulic pto for it and then buying or building a splitter from that. You are going to want the lift cylinder for attatchments and if you ever go to sell it you will lose most if all of its value by hacking the hydro system. Just my 02. Cents!
#6 kencombs OFFLINE
kencombs
  • 31 Thanks
  • 41 posts
Posted July 31, 2015 - 09:56 AM
That is not a good idea.  two issues: first, the lift circuit is limited to about 575psi by the relief in the valve  Second, those small lines will take forever to move a large cylinder
You  need to follow the Case plan for running a splitter.  The pump output should go first to the PTO valve .  that makes all the pump flow available to the splitter and the pressure is controlled by the PTO valve's relief..
#7 Alc ONLINE
  • 7,131 Thanks
  • 7,533 posts
Posted July 31, 2015 - 10:34 AM
I'm glad this thread was started , I always wanted a Case because I thought it had strong enough hydraulics so you could run log splitters and such without an extra pump ?  Different models ?
#8 kencombs OFFLINE
kencombs
  • 31 Thanks
  • 41 posts
Posted July 31, 2015 - 01:23 PM
Yes they do have strong enough hydraulics.  you just need to install as I outlined above, which is the Case recommended method.
Pump to pto, pto to main control valve.  When the pto valve is open the attachment receives all the pump flow before any other use.
#9 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted July 31, 2015 - 03:00 PM
