Another weed control method we use.
12 replies to this topic
#1 propane1 ONLINE
propane1
  • 13511 Thanks
  • 5961 posts
Posted July 29, 2015 - 04:41 PM
You probably already do this most of you. What do you think, good or bad. Just woundering, Noel
Oops, two pictures are sideways.
  • Alc, boyscout862 and oldedeeres have said thanks
#2 boyscout862 OFFLINE
  • 15188 Thanks
  • 9998 posts
Posted July 29, 2015 - 05:13 PM
IF that is mulching with grass clippings, I do it too. Good Luck, Rick
  • propane1 said thank you
#3 DennyIN OFFLINE
DennyIN
  • 503 Thanks
  • 276 posts
Posted July 29, 2015 - 07:27 PM
That is what I do too, but try to tuck a layer of newspaper under and next to the plants first, then lay down the grass clippings.
  • Alc, oldedeeres and propane1 have said thanks
#4 devans OFFLINE
devans
  • 371 Thanks
  • 257 posts
Posted July 29, 2015 - 07:43 PM
I used to mulch my corn with grass clippings when I had a garden. The nitrogen it gave off really made the plants jump in size and fast.
#5 shorty OFFLINE
shorty
  • 6033 Thanks
  • 5507 posts
Posted July 29, 2015 - 08:04 PM
I like to use grass clippings in the garden too. How about a closer pic of that rake.
#6 propane1 ONLINE
propane1
  • 13511 Thanks
  • 5961 posts
Posted July 29, 2015 - 08:58 PM
This better. Or need closer. If you need closer, I will have to get a new picture. It's called an estate rake. You can also find it on the internet. Noel.
  • shorty and oldedeeres have said thanks
#7 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1692 Thanks
  • 1148 posts
Posted July 29, 2015 - 09:44 PM
  Propane1, why is the weight needed?
                                   Mike
#8 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted July 29, 2015 - 10:22 PM
Since those rakes are not mounted to the tractor, they could have a tendency to slide sideways while raking.
Mike
When they are mounted to the tractor, they can't scamper off to one side
[vid][/vid]
The tow behind could, if not weighted down. Here is a video from the company
[vid][/vid]
  • CRFarnsworth and oldedeeres have said thanks
#9 daytime dave OFFLINE
  • 5478 Thanks
  • 6780 posts
Posted July 30, 2015 - 12:46 AM
Noel
I've used grass clippings before.  It worked well.  This year I used last years leaves that I piled up in the spring.  They have worked well also.
#10 propane1 ONLINE
propane1
  • 13511 Thanks
  • 5961 posts
Posted July 30, 2015 - 04:15 AM
Mike, it depends on how low the rakes are. There is adjustment for how far down you go. You can just skim the top or dig in. It will tear some grass out of the ground, if down all the way. So it will push the rake sideways in some cases. The weight is needed to help give the tires traction to stop slipping. What I was doing there was wet long grass, which was heavy. Normal raking of a lawn, the rake does not push sideways. Noel.
  • MH81, Alc and KennyP have said thanks
#11 KennyP ONLINE
  • 52587 Thanks
  • 53118 posts
Posted July 30, 2015 - 04:44 AM
Nice rake, Noel!
#12 propane1 ONLINE
propane1
  • 13511 Thanks
  • 5961 posts
Posted July 30, 2015 - 05:43 AM
It all so works good for leafs and general debris. Noel
#13 oldedeeres OFFLINE
oldedeeres
  • 15500 Thanks
  • 6832 posts
Posted July 31, 2015 - 02:30 PM
Me too.
