I'm trying to id a tractor with partial number
28 replies to this topic
#16 4tom OFFLINE
4tom
  • 164 Thanks
  • 178 posts
Posted December 22, 2016 - 01:08 PM
It came with a 42 inch deck. I added a snow plow. I believe the model number prefix to be 917 based on instructions for installing the plow. If the serial does start with the date my motor is not original. I am having a little trouble with the front axle. Called sears repair center the person I spoke to said without a model number I'm screwed if I need parts.
Edited by 4tom, December 23, 2016 - 12:54 PM.
#17 4tom OFFLINE
4tom
  • 164 Thanks
  • 178 posts
Posted December 22, 2016 - 01:52 PM
I confirmed engine is November 2000 with briggs & Stratton. Cutting deck is 42" but may or may not be original. If date format of serial number is accurate it reads September 97. I don't obsess over it, but occasionally try a little research. May need to repair front axle soon. Trying to confirm the date format of the serial number. Kind of suspect somebody before me may have frankensteined it from a stack of donors.
#18 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted December 22, 2016 - 01:56 PM
One thing about Sears. If you can find a model # close to your tractor, then the parts will fit. I found a manual I want you to look through to see if it's close to your tractor.
Attached File  L9060049.pdf   2.27MB   16 downloads
#19 Cjet69 OFFLINE
Cjet69
  • 727 Thanks
  • 386 posts
Posted December 22, 2016 - 02:04 PM
Found a site that states serial number starts with a date code: month day year 2 digits each. If true mine decodes to September 9 1997. Engine still decodes as November 2000. Can anyone confirm serial numer starts with day of manufacture?
Thanks
Merry Christmas
That is correct, 2 digits each, month/day/year. --/--/--
#20 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted December 22, 2016 - 02:05 PM
Didn't know that!
  • Cjet69 said thank you
#21 4tom OFFLINE
4tom
  • 164 Thanks
  • 178 posts
Posted December 22, 2016 - 02:29 PM
Slowly making progress. Now it's time to start Christmas shopping.
Thanks for the help
Have a very merry Christmas
Edited by 4tom, December 22, 2016 - 02:34 PM.
#22 Cjet69 OFFLINE
Cjet69
  • 727 Thanks
  • 386 posts
Posted December 22, 2016 - 04:31 PM
Didn't know that!
I just recently learned this also when I picked up a  this craftsman. First 6 numbers in serial #. 06-04-97
Edited by Cjet69, December 22, 2016 - 04:31 PM.
#23 MH81 OFFLINE
  • 29,979 Thanks
Posted December 22, 2016 - 05:16 PM
i cant remember when the Julian dating style changed.
at some point it was that way, but at some point previous it was day of the year, then year.
ie 12592 was the 125th day of 92.
i may not have all the facts straight, gotta look them up again. it was some derivation of that tho
  • KennyP and Cjet69 have said thanks
#24 JiminRI OFFLINE
JiminRI
  • 91 Thanks
  • 80 posts
Posted December 22, 2016 - 08:24 PM
From ehow.com:
How to Determine the Age of a Craftsman Riding Mower
By Jason Alexander - eHow Contributor
http://www.ehow.com/...ding-mower.html
Craftsman lawn mowers use a serial number formula that reveals your mower's manufacture date. By locating the serial number tag on your machine, you can easily determine your mower's age. If you have the owner's manual for your mower, you can also check the date printed on the inside of the manual. This date should be one year after the mower's manufacture date. However, your serial number provides the exact date your mower came off the manufacturing line.
  • Locate the identification decal on your lawn mower. Craftsman mowers have stickers with a serial number and date printed on them. This tag is usually located in a protected area on, beneath or near the seat of the riding mower.
  • Write down the first six numbers of the mower's serial number. The first two numbers are the mower's month of manufacture. The second two numbers indicate the day of manufacture and the third two will signify the year of manufacture.
  • Use the Craftsman serial number formula to determine your mower's specific age. For example, if the first six numbers of your model's serial number are 031398, your mower was manufactured on March 13, 1998.
From another thread here:
Sears Date Codes  - apparently applies to older tractors only.
http://gardentractor...ars-date-codes/
JULIAN DATE SYSTEM
#917.254810     917 = source.     254810 = model
serial number 0521B01538
052 represents the day of year
1 last digit of year
B plant code
1538 number of unit made
From yesterdays tractors:
B&S engine serial number decode
http://www.yesterday...ardent&th=93626
If a Briggs engine, check the CODE number on the engine. The first two numbers are the YEAR the engine was built. The next two are the MONTH. You can come close with, if you have them, these numbers.
#25 4tom OFFLINE
4tom
  • 164 Thanks
  • 178 posts
Posted December 22, 2016 - 08:58 PM
Interesting
My sheet metal is different, your wheels look to have lug nuts while mine have a single nut onto the axle.
I am guessing I have a lt1000 or 2000, but I don't have much to base that guess on.
Thanks for sharing!
#26 Cjet69 OFFLINE
Cjet69
  • 727 Thanks
  • 386 posts
Posted December 22, 2016 - 09:15 PM
Interesting
Thanks for sharing!
I just posted my tractor for serial # date code reference.
#27 MH81 OFFLINE
  • 29,979 Thanks
Posted December 22, 2016 - 09:36 PM
From ehow.com:
JULIAN DATE SYSTEM
B plant code
That sounds right.
Thanks for finding it
#28 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted December 23, 2016 - 06:10 AM
I'm going to add that info to my thread so folks can find it easier.
#29 4tom OFFLINE
4tom
  • 164 Thanks
  • 178 posts
Posted December 23, 2016 - 12:53 PM
My serial number date code is followed by letter D. Does anyone know other plants than above? Just curious.
Tom
