I'm trying to id a tractor with partial number
28 replies to this topic
#1 4tom OFFLINE
4tom
  • 153 Thanks
  • 165 posts
Posted July 29, 2015 - 06:37 AM
It's a green 21 hp briggs&stratton craftsman tractor with 12 gauge 42" cutting deck. Partial model number looks like it ends with: 547
What can I look for to try to id it ?
Thanks!
Edited by 4tom, July 30, 2015 - 05:28 AM.
#2 MH81 OFFLINE
Posted July 29, 2015 - 06:40 AM
This may be very difficult as Sears will change model numbers every time they change bolt size.
First step would be to take a pic of the critter and upload it.
Click the "More Reply Options" button down and to the right and you should be able to upload pics there.
  • 4tom said thank you
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted July 29, 2015 - 08:19 AM
:welcometogttalk: :camera:
#4 boyscout862 ONLINE
  • 12,842 Thanks
  • 9,166 posts
Posted July 29, 2015 - 08:38 AM
Welcome to GTT. Good Luck, Rick
#5 HANKG ONLINE
HANKG
  • 6,307 Thanks
  • 3,421 posts
Posted July 29, 2015 - 09:34 AM
Welcome aboard , always good to have another Jerseyan at GTTalk where you from ?
#6 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted July 29, 2015 - 03:36 PM
Look for any labels, If you find one, and it's un readable, get up real close with a magnifying glass in good light. Study it from all angles to see if you can see the imprint of the numbers.
Craftsman equipment labeling has a bad habit of fading out after a few years.
#7 4tom OFFLINE
4tom
  • 153 Thanks
  • 165 posts
Posted August 01, 2015 - 02:10 PM
I'm in Brick.
Found sticker says engine conforms with 2000-2001 California emissions
Rear tires have slow leak, presume tube would cure that maybe with sealant inside tube. Sound about right ?
More pics attached:
#8 MH81 OFFLINE
Posted August 01, 2015 - 06:21 PM
Are you trying to ID it for parts or ?
Slow leak, yeah... Tubes will work.
I actually have had good luck with a half cup of antifreeze in the tire and drive it around for a while. Seems to work as well as slime for some reason.
#9 4tom OFFLINE
4tom
  • 153 Thanks
  • 165 posts
Posted August 02, 2015 - 05:29 PM
Yes, I am trying to identify it for when I need parts. Sooner or later everything breaks, usually not at a convenient time. Searsfolks won't let me order even a mulching kit without the model number. After a number of calls I found a rep who placed the order. Real PITA to do even that.
#10 JiminRI OFFLINE
JiminRI
  • 91 Thanks
  • 80 posts
Posted August 06, 2015 - 09:50 PM
I used the Sears fit-up guide (see attached) to search for tractors with model numbers ending in 547. There was only one 917.25547 but it is a 14 hp engine. From your picture I tried 347 and found 917.273470 which looks more like your tractor but has a 20 hp. I then tried 847 and found 917.25847 but that has a 15.5 hp B&S.
Perhaps you can try other combinations.
Good luck,
JiminRI
Edited by JiminRI, August 06, 2015 - 10:23 PM.
  • drbish and 4tom have said thanks
#11 4tom OFFLINE
4tom
  • 153 Thanks
  • 165 posts
Posted August 10, 2015 - 08:27 PM
I think I have narrowed it down to a 2000 or 2001 model. Is there a list of available models, or online catalog I can access to try and identity what I have ?
Thanks!
#12 4tom OFFLINE
4tom
  • 153 Thanks
  • 165 posts
Posted February 01, 2016 - 01:09 AM
Added a plow from sears. Based on description of spindles in the instructions, it is a 917 prefix model.
Edited by 4tom, February 01, 2016 - 04:28 AM.
#13 4tom OFFLINE
4tom
  • 153 Thanks
  • 165 posts
Posted December 22, 2016 - 11:12 AM
Found a site that states serial number starts with a date code: month day year 2 digits each. If true mine decodes to September 9 1997. Engine still decodes as November 2000. Can anyone confirm serial numer starts with day of manufacture?
Thanks
Merry Christmas
#14 KennyP OFFLINE
  • 38,296 Thanks
  • 45,895 posts
Posted December 22, 2016 - 11:36 AM
Wow! This could be a hard one to figure out, as I see you still haven't! I have no idea what Sears does with model/serial #'s nowadays. How wide does it cut?
#15 DougT ONLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted December 22, 2016 - 12:43 PM
The first 3 digits of the Sears number is the source code. That tells who built the tractor. The first digits of the Briggs engine code is the manufacture date for the engine.
