Original question again
5 replies to this topic
#1 bryan 110 OFFLINE
bryan 110
  • 220 Thanks
  • 289 posts
Posted July 28, 2015 - 07:23 PM
Ok so we got the tractor to run. But it won't rev up? What's up with that?
I am going to be puting a carb kit in it also. Just because it was so gummed up (but cleaned befor trying to run)and I already have a kit.
Anyways thanks for the help guys. I love this site for that...
  • oldedeeres said thank you
#2 boyscout862 OFFLINE
  • 12,551 Thanks
  • 9,044 posts
Posted July 28, 2015 - 11:19 PM
While rebuilding the carb, replace the fuel lines and fuel filter too. Make sure the tank is clean, Good Luck, Rick
#3 Bill 76 ONLINE
Bill 76
  • 1,892 Thanks
  • 1,178 posts
Posted July 28, 2015 - 11:51 PM
Is all the throttle cable and governor linkage hooked up correctly ? Is the butterfly open all the way with engine off and throttle lever set on full speed ?
#4 MH81 OFFLINE
Posted July 29, 2015 - 06:31 AM
Will it rev up more if you add a little choke?
#5 bryan 110 OFFLINE
bryan 110
  • 220 Thanks
  • 289 posts
Posted July 29, 2015 - 04:15 PM
Works just fine on starting fluid but that's right down the barrel of the carb. So I was thinking maybe something is still gummed up. I did clean the tank and new fuel line and fittings. It has a sediment bowl and that is clean.
I cleaned the tank with nails and the case 220. Hooked the tank to one of the rear wheels and mowed my mom and dad's lawn.
#6 Tankman OFFLINE
Tankman
  • 298 Thanks
  • 299 posts
Posted July 30, 2015 - 02:17 PM
Perhaps start using Berrymans B-12 in the fuel.
I've had outstanding results using Berrymans fuel additive. On occasion I also purchase 100LL (100 octane low lead - ethanol free) gas at a local airport.
Small engine mechanics love ethanol, keeps them in the money making repairs.
