Gas hedge trimmer question
1 reply to this topic
#1 dogsoldier OFFLINE
  • 361 Thanks
  • 509 posts
Posted July 28, 2015 - 04:23 PM
A friend dropped off a older Craftsman Hedge Trimmer Model 358 795781
he said it wouldnt start, i put gas in it a it tried to start on the first pull,
( funny how gas works ) anyway, on the 3rd pull the pull cord wouldnt go back in.
i have never messed with one of these things so i thought i would
come here and ask.
What is the best way to get the cord back in?
#2 Gtractor OFFLINE
    the homeless tractor hoarder
  • 9,497 Thanks
  • 5,007 posts
Posted July 28, 2015 - 04:43 PM
The recoil could be dried out, gummed up, or dirty and causing enough drag to overpower the return spring.
The return spring could have broken.
Take the recoil off and you should be able to see whats going on.  Probably an easy fix.
There are several video's on how to fix recoil starters on YouTube.
P.S.  If the spring has broken the end off [common problem] you can grind a new notch and it'll work again.  I've done many that way over the years.
Edited by Gtractor, July 28, 2015 - 05:22 PM.
