EVER HEAR OF FASCIITIS
25 replies to this topic
#16 jimbobbillyray ONLINE
jimbobbillyray
  • 3,159 Thanks
  • 2,934 posts
Posted July 28, 2015 - 08:40 PM
i found shoe inserts at walgreens, used them for about a year, healed up. when u get out of bed in the morning is when it is the most painful. doc showed me stretch to do first thing when i got out of bed each morning
  • MH81, boyscout862 and HANKG have said thanks
#17 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 28, 2015 - 09:11 PM
Not had that, but have had a few flareups of gout a year for over 30 yrs now.
That is no fun either.
  • boyscout862 and HANKG have said thanks
#18 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted July 28, 2015 - 09:21 PM
I've had it a couple times, proper footwear seems to be the main "preventative"!  I've various therapies, including shots in my heal (big ouch), battery powered medication pads & others.  Podiatrist tells me no moccasins, barefoot or heal-less shoes!
  • jimbobbillyray, boyscout862 and HANKG have said thanks
#19 jimbobbillyray ONLINE
jimbobbillyray
  • 3,159 Thanks
  • 2,934 posts
Posted July 28, 2015 - 09:29 PM
got that too.  Thanks Dad!   (male side of family hereditary)   I avoid green beans and shrimp
#20 tater195 OFFLINE
tater195
  • 2,264 Thanks
  • 1,443 posts
Posted July 28, 2015 - 09:58 PM
...and cola.. and beer,,,,
#21 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 28, 2015 - 10:31 PM
My dr tells me Gout is a build up of uric acid causing crystals to form in the joint.
It is these crystals rubbing on nerves that causes the irritation.
I can be a skeptic at times, and did not believe this when my wife's uncle told me that sour cherries would reduce uric acid.
When in pain I will do anything for some relief. This. Works for me.
I recommend eating a cherry pie when you have a flare up!
May need one tomorrow, had shrimp for lunch today.
Edited by MH81, July 29, 2015 - 06:41 AM.
#22 oldedeeres OFFLINE
oldedeeres
  • 10,483 Thanks
  • 5,093 posts
Posted July 28, 2015 - 11:41 PM
I have had this as well, spent a while researching it on Google, and found that rolling my arch over the bar under the kitchen table, ( similar to the recommended rolling pin), worked wonders.
#23 jimbobbillyray ONLINE
jimbobbillyray
  • 3,159 Thanks
  • 2,934 posts
Posted July 29, 2015 - 08:03 AM
Black cherry soda pop does the trick for me....
Edited by Delmar, July 29, 2015 - 08:03 AM.
#24 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,174 Thanks
  • 2,254 posts
Posted July 29, 2015 - 08:16 AM
Had this flare up to the point i could hardly walk.
Best cure for me has been arch support inserts from Red Wing and stretching my calve muscles and feet.  I will stand on a step with the front of my feet supported and then lower my heels as far as I could.  This was a morning ritual every day on the way into the building at work.  Made a huge difference in my comfort level. Even got some co-workers into doing the same thing.    Rick
  • boyscout862, oldedeeres and HANKG have said thanks
#25 Canawler OFFLINE
Canawler
  • 1,951 Thanks
  • 1,806 posts
Posted July 29, 2015 - 12:49 PM
I went through this a few years ago. I had the pain get progressively worse for about a year. I tried all the usual treatments with zero relief: physical therapy, custom orthotics that didn't fit in any normal shoe known to man, the arch stretching elf boots that were mentioned earlier, the rolling pin stretches, three rounds of cortisone shots in the heel (no fun,) you name it. What did the trick for me are Walk Fit brand orthotics picked up for $20 from Target. They're semi rigid with a replaceable hard arch support. They give you three different height supports to stretch the arch and the inserts fit just about every shoe I have. After having the condition for a year+, the pain cleared up in about a week of regular use of the insole. They're still an everyday thing for me.
  • LilysDad and oldedeeres have said thanks
#26 jimbobbillyray ONLINE
jimbobbillyray
  • 3,159 Thanks
  • 2,934 posts
Posted July 29, 2015 - 03:31 PM
that is the stretch the doc showed me to do!    I found another one that works sometimes too, when I get out of my truck I will use the wheel/tire on my truck to push down my foot to stretch it while holding on to the fender so I don't fall over.
Edited by Delmar, July 29, 2015 - 03:33 PM.
  • oldedeeres said thank you
