whats a good way to bleed hyd. system
2 replies to this topic
#1 york0060 OFFLINE
york0060
  • 309 Thanks
  • 146 posts
Posted April 06, 2011 - 08:09 AM
i have a case 220 and i need to bleed the air out of the hydralic system. does anyone know a vent area to bleed or a easy way to do it?
#2 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted April 06, 2011 - 09:29 AM
I was always under the assumption that the hydraulic system will self bleed, after an oil change or the system being drained and refilled you would want to make sure the tank was topped to the full mark and then cycle each cylinder at least 3 times and repeat as necessary. Just don't quote me on that though.
#3 Billygoat OFFLINE
Billygoat
  • 76 Thanks
  • 206 posts
Posted April 06, 2011 - 12:23 PM
Yep, just run it forward and reverse, run the lift up and down. Pretty much self bleeding, keep check on oil level. If your still getting air you may have a leak on suction side of pump.
