help with throttle linkage on David Bradley Big 5
2 replies to this topic
#1 dblover OFFLINE
dblover
  • 267 Thanks
  • 160 posts
Posted July 26, 2015 - 09:51 PM
How does the throttle cable attach to the linkage to the carb?  The prior owner used a "c" clamp to attach the throttle wire to the alum block linkage to the carb.   No details in manual for 917575100.  Thanks.
Edited by dblover, July 27, 2015 - 12:15 PM.
#2 Nxt2doc OFFLINE
Nxt2doc
  • 630 Thanks
  • 335 posts
Posted July 27, 2015 - 12:57 PM
From the looks of things I would say it fits through the hole side to side with a screw anchoring it from the top.
Edited by Nxt2doc, July 27, 2015 - 12:58 PM.
  • dblover said thank you
#3 dblover OFFLINE
dblover
  • 267 Thanks
  • 160 posts
Posted July 27, 2015 - 10:37 PM
Nxt2doc had the answer. Someone sent me a B&S manual showing all the various linkages used on the engine. I found it there. Bending the throttle cable 90 degrees to go into the block is not going to win any engineering awards, but it worked.
