Finally bought a plow!
69 replies to this topic
#46 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 06, 2015 - 12:17 AM
I have to state this, the reason your plow isn't lifting off the ground is that hitch piece bolts solid to the plow with 2 bolts. So once you have that piece rewelded to the correct angle of 10 degrees (as Alan stated) and bolted back on solidly, you should see the plow lift off the ground. Good luck.
#47 OldBuzzard ONLINE
OldBuzzard
  • 7,080 Thanks
  • 4,809 posts
Posted August 06, 2015 - 12:28 AM
As cheap as that part is from Brinly, I think I'd just buy one from them and be done with it.
That way you know that it will be correct.
#48 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted August 06, 2015 - 08:06 AM
Casey, The plow wasn't lifting off because I used that other bolt hole on the hitch. It lifts fine on the regular setting, it just doesn't track right, but that's on both settings.
OB, I'll try my luck at having it rewelded, I've got a machinist 2 miles away as a last resort if Dad and I can't do it. I think we can though. If all else fails Brinly will get an order in :D
  • wvbuzzmaster and propane1 have said thanks
#49 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 06, 2015 - 01:19 PM
No problem. It looked as though you were only using one bolt (im guilty of doing that when im disassembling often)
#50 propane1 OFFLINE
propane1
  • 9,119 Thanks
  • 4,274 posts
Posted August 06, 2015 - 02:24 PM
Could you put few better pictures of the point on the plow. It looks worn out, but it's hard to see. Thanks, Noel.
Edited by propane1, August 06, 2015 - 02:25 PM.
#51 propane1 OFFLINE
propane1
  • 9,119 Thanks
  • 4,274 posts
Posted August 07, 2015 - 09:59 AM
These are from my plow. Hope it helps. Noel
Oops, one upside down. Sorry.
#52 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted August 07, 2015 - 10:14 AM
Thanks Noel! So yours is just straight up and down, not angled?
  • propane1 said thank you
#53 MH81 OFFLINE
Posted August 07, 2015 - 11:00 AM
No, his is angled too. You can see it if you look close.
#54 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted August 07, 2015 - 11:59 AM
Aha! I see it now. Thanks for pointing that out!
Attached is a pic of the tip:
#55 propane1 OFFLINE
propane1
  • 9,119 Thanks
  • 4,274 posts
Posted August 07, 2015 - 12:40 PM
You have to look at the underneath of the point. The point has to be tipped down so it will dig in, not tipped up. If its worn so it's tipped up, the plow will want to pull up out of the ground. To make it dig, you have to adjust the point tip down more, which then puts the landslide up at the back. The point is suppose to have, what is called , suck, under the point to keep the plow in the ground and not ride up out of the ground and then you can adjust the plow so the landslide is down in the back.   Could you show a picture of the underneath of the point.  Hope this helps.  Noel
#56 propane1 OFFLINE
propane1
  • 9,119 Thanks
  • 4,274 posts
Posted August 07, 2015 - 01:08 PM
Pictures of points. Not quite what picture I was looking for, but you get the idea. Noel.
#57 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted August 07, 2015 - 01:29 PM
Yep, I see what you mean. I'll have to get a pic when I go out again.
Ok, something really awesome just happened! At our county fair, a guy from our Tractor Club (Northland Oliver collector's Association   http://www.northlandoliver.com/) Told me he had a present for me. I had no clue what it was until he stopped by today. He saw my Gt at the fair and said he had something I would like, when he opened the tailgate of his pickup, I couldn't believe it! There he had a Brinly sleeve hitch plow in pieces!! So now I have 2 plows and, yep, the correct hitch piece!!! Immediately after he left I tore the old one off, put the new one in and plowed the manure pile. You could tell something was different, it's finally right! It still needs adjusting, and I'll do that probably when we dig all the potatoes and onions out of the garden. I'll get some pics of it when it's assembled!
  • MH81, KennyP and propane1 have said thanks
#58 KennyP ONLINE
  • 40,044 Thanks
  • 46,732 posts
Posted August 07, 2015 - 04:18 PM
Glad you have it working for you!
#59 propane1 OFFLINE
propane1
  • 9,119 Thanks
  • 4,274 posts
Posted August 07, 2015 - 04:51 PM
That's great, can't wait for the pictures. Have fun with it. Use the other plow to make another type of attachment, just for fun, if you don't need it for some thing. Noel
#60 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted August 07, 2015 - 04:53 PM
Just a note about the point. I did not think mine was too bad, it was already old when I got it and I plowed with it for 3 years. I bout a new share last year and WOW what a difference. It really changed the way the plow worked. I would suggest buying a new one before next spring, it will make a huge difference.
