Wheel Horse RJ-58 Restoration
75 replies to this topic
#46 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted July 29, 2016 - 06:48 PM
Glad I don't have one of those!
#47 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted July 31, 2016 - 07:12 PM
Dug the motor out today and started removing the tin work so I could open it up and take a look inside. I removed the head first, and was quite surprised to find no major carbon build up. Even the piston and valves are fairly clean. If this motor is original and has never been rebuilt, it couldn't have possibly been used very hard. No markings on the piston, so it has to be standard bore yet.
After being satisfied with the top end of the block, I figured I'll drain the oil and pull the oil pan off so that I could see what the bottom end looked like. Other than the ugly primer on the inside of the block, everything looks good and tight. Not sure now how I want to approach this motor. Should I rebuild it or not? It has good compression, and since everything looks to be in pretty good shape, I may just take my chances on this one and hope for the best.
  • Bolens 1000 and KennyP have said thanks
#48 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted August 01, 2016 - 07:05 AM
I think I'd just put it back together and run it. Be sure to check that governor gear, though.
  • johndeereelfman and MolonLabe have said thanks
#49 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted August 01, 2016 - 07:52 AM
That's not primer in the block, if I had a guess it is glyptol. Used to paint the oil side of allot of things, allows the oil to slide back down into the pan faster, helps to keep oil from soaking into and seeping out of the block and keeps the oil cooler to boot.
I have a very old Toro engine and the pan was split from water freezing, I tried to weld it but just wound up with 100s of hairline cracks. I ground and smoothed the weld then painted it with glyptol inside and out and it has never leaked even with marvel mystery oil in there for the last 2 years.
Pete
  • johndeereelfman, backwoods, TomLGT195 and 1 other said thanks
#50 MolonLabe ONLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 319 posts
Posted August 01, 2016 - 03:46 PM
Gotta say I would button it back up. If it were a worker it would be a different story but I'm pretty sure you aren't planning on plowing a field with it. Those old K90, K91 engines are as tough as nails.  :thumbs:
  • Bolens 1000 and johndeereelfman have said thanks
#51 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted August 01, 2016 - 04:19 PM
Yea, that's what I think I'll do. I guess if it ain't broke, why fix it, right?
Thanks for the input guys!  :thumbs:
#52 Bolens 1000 ONLINE
  • 14,890 Thanks
  • 18,097 posts
Posted August 01, 2016 - 04:34 PM
If she dosent smoke and has good compression I say leave it alone , the only thing maybe is check valve clearances and lap them while its apart but would leave the rest alone.
#53 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted August 03, 2016 - 07:47 PM
Tonight I got the seat pan completely stripped and first coated with primer:
I also got the NOS Recoil out of its box, cleaned up, and first coated with finish:
#54 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted September 09, 2016 - 06:33 PM
Not a whole lot of time lately due to my current work schedule, however since posting last time, I did manage to get a couple more pieces stripped, primed, and first or second coated with finish.
Seat Pan:
Tool Box:
Frame:
Belt Guard:
Heat Shield:
Transmission Shift Lever:
#55 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted September 10, 2016 - 09:47 PM
Today I was able to get some more painting done. The last coats were applied to the transmission housing and side plates:
I also got the second or third coats applied to the seat spring, rear cooling tin, and main blower housing:
I decided to start assembling the differential, however before doing so, I needed to replace the main bushings. I carefully cut the old bushings out using a hacksaw blade, and then prying up a corner and sliding them out. Once the new bushings were installed, I needed to cut off a 1/4" so I used the Dremel and a cutoff wheel:
After the new bushings were install and completed, I needed to drill a 1/4" hole in the end of each axle shaft, as I decided to flip the axle end for end, since the old bushings wore the shafts pretty good. The key ways were already there, so the holes were the only things needed:
With the axle shafts drilled and done, it was then time to start assembling the differential. Once the differential was assembled, I lubed it real good with petroleum jelly as a way of keeping the rust to a minimum until I'm ready to assemble the complete transmission:
I also got all of the transmission bolts and plugs stripped and first coated with aluminum. I was going to just go with new stainless steel hardware, however I have parts that will be attached to this transmission that are painted silver, and I don't think the silver and stainless steel will look good together. If I find that I don't like the aluminum painted hardware, I can always go back later and repaint them all red to match the transmission:
I also made a trip to the local hardware store where I buy my paint, and ordered the two cases of acrylic lacquer clear coat. It should be here by Tuesday, so I'm excited to get these parts coated and done. Can't wait to see what the results will be like when I'm done. With the way these parts are shinning now, I can't imagine how well they will shine once the clear coat is on.
Edited by johndeereelfman, September 10, 2016 - 09:50 PM.
  • Alc, KennyP, TomLGT195 and 1 other said thanks
#56 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted September 11, 2016 - 07:12 PM
Got a little more accomplished today, although it doesn't appear to be that much. Most of my day was spent cleaning nuts and bolts.
I was able to get another coat of finish on the frame:
I got a first coat of finish on the oil bath breather:
And after soaking in 100% apple cider vinegar for the past two weeks, I decided to see how well the nuts and bolts would clean up. I must say, I'm very impressed with this method, as all of the rust is gone. All I had to do was go over each piece with a wire brush. Here are some before and after pictures:
  • KennyP and TomLGT195 have said thanks
#57 shorty ONLINE
shorty
  • 5,273 Thanks
  • 5,160 posts
Posted September 11, 2016 - 08:20 PM
Slowly getting there Troy. Are you still working the long weeks?
#58 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted September 12, 2016 - 07:17 AM
Looking good, Troy! The vinegar does a good job.
#59 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted September 12, 2016 - 08:18 PM
Unfortunately yes Eric. But then again, I guess I should say Fortunately as this job is better than the one I left Spring of last year!  :thumbs:
  • shorty said thank you
#60 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted September 12, 2016 - 08:20 PM
Thanks Kenny. I am very impressed with the vinegar, have you ever tried it out? Was just curious to see if anybody else had as good of results.
