Original cub
#1
OFFLINE
Posted July 25, 2015 - 08:04 PM
I put. New points in new wire harness checked 4 times to make sure wiring was hooked up right.
#2
OFFLINE
Posted July 25, 2015 - 08:36 PM
Timing? Fuel? Air Leak? Flywheel key? Bad Cap?
Edited by larrybl, July 25, 2015 - 08:37 PM.
- boyscout862 said thank you
#3
OFFLINE
Posted July 25, 2015 - 08:44 PM
Was it running before you put in the new points and wire harness? For the engine to run, it has to have decent compression, a good hot spark, and the right fuel/air mixture at the right time. Does it have compression? Will it run briefly if you spray a little starter fluid in the throat of the carburetor? If you're getting a good hot spark and it won't run when you spray starter fluid in the carb, then you may have a timing problem or low compression. If it does run briefly with starter fluid, then you probably have a fuel system problem.
#4
OFFLINE
Posted July 26, 2015 - 04:49 AM
Stuck valve ?
#5
OFFLINE
Posted July 26, 2015 - 10:04 AM
- superaben said thank you
#6
OFFLINE
Posted July 26, 2015 - 11:32 AM
If I had a nickel for every time I had read or heard "Just kind of going by the po "it ran when we parked it"." I would be hanging out in the CUT section by now.
#7
OFFLINE
Posted July 26, 2015 - 12:22 PM
#8
OFFLINE
Posted July 26, 2015 - 06:55 PM
