New tecumseh carb
44 replies to this topic
#31 MH81 OFFLINE
  • 29,978 Thanks
Posted July 26, 2015 - 10:34 PM
Does it do it when the mower deck belt is uninstalled?
Also, it almost sounds like something is rubbing. I can't see the guide on the idler back in... Are you certain all the guides are where they belong and aren't rubbing on the belt. Real easy to do on the one down in... Especially with the deck on
  • Firefighter912 said thank you
#32 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 26, 2015 - 10:44 PM
Well the mower belt hasn't rubbed too much. It's the drive belt that's smoking bad. I need to check the middle pulley then.
Does the drive belt move though at idle?
#33 MH81 OFFLINE
  • 29,978 Thanks
Posted July 27, 2015 - 06:05 AM
That belt will move any time the clutch pedal is up. Shouldn't move when the clutch is down.
If its smoking, there has to be wear. Where is it rubbing?
#34 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 27, 2015 - 09:43 AM
The middle pulley that you adjust..the guide is rubbing belt.
I'll get it fixed today.
Ok. How do you guys have you governor set?
Where do I get an rpm gauge?
Edited by Firefighter912, July 27, 2015 - 09:43 AM.
#35 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 27, 2015 - 04:27 PM
Looks like I'm missing a fix speed screw for the govenor. Yall know what Size screw it is?
#36 MH81 OFFLINE
  • 29,978 Thanks
Posted July 27, 2015 - 04:44 PM
If its the one I think you mean, I think its a 12 or 10 by 24
#37 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 27, 2015 - 05:26 PM
How the hell do you set this governor? I looked at the manual and still don't get it.
I'm about damn tired of it.
#38 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 27, 2015 - 05:37 PM
I'm just going to carry it to a shop. I'm tired of getting frustrated. I've tried.
#39 WHdbJD ONLINE
WHdbJD
  • 701 Thanks
  • 523 posts
Posted July 27, 2015 - 05:54 PM
Don't give up yet, just walk away for a bit. I've been there, frustrated, aggravated and pizzed off.
You've got several posts here, about different problems, I think you may be trying to fix too many things at once, ....
Concentrate on one thing , get it resolved, and move to the next.
The guys on this forum are great, they will walk you thru most anything!
#40 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 28, 2015 - 01:31 PM
Yeah I know. But im fed up with it right now. I'm taking it to the shop. Let them deal with it and once they find the issue then I'll know.
I'm just ready to use it
#41 MH81 OFFLINE
  • 29,978 Thanks
Posted July 28, 2015 - 05:09 PM
Hopefully they get it back to you soon.
#42 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 28, 2015 - 06:19 PM
I hope. I appreciate the help guys. Seriously. But I have no more patience with it right now. I'm ready to work.
Guy at mower shop says he hasn't seen one of these in a long time
#43 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted August 21, 2015 - 09:31 AM
Well I've been away out west and finally made it home for a bit.
I called the people at the shop and the guy whose been working on it is gone to Dr appointment and won't be back til Monday. the guys there say it's running but it's spitting and spuddering some.
they said the carb might need to be cleaned od get a new one. they asked me if i had the air filter stuff and i said yes. I told them it is new carb as well. got it a month ago.they also said it looked like some linkages are missing. maybe has water in gas. they said I can come and look at it and hear it run and if it's ok it'll be $40.
I told them it might need the air baffle I got cause it may be leaking air with the spacer I made.
so we'll see.
#44 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted September 30, 2015 - 11:49 PM
Well I have finally gotten my little tractor back from the shop. They got it set good and it runs. I've mowed with it today but I kind of have to play with the choke some. If I close it all the way..the engine wants to be sluggish sometimes or rev up and rev down like it's starving for air or fuel. Once I pull back on the choke some and open it...it settles out some and runs decent.
So far I like it...our place is thick with weeds/grass so it will take some time to go over it. I've also notice the belt wants to try to engage the blade when I have the deck off when driving along.
Also if I get in some thick stuff..the belt starts smoking..lol
#45 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted November 15, 2015 - 12:21 AM
How is that tecumseh working for you now? I do alot of tecumseh engines for people if you have any more questions feel free, and if it is still surging I can try to help you fix that. I have a good idea of what it is
