New tecumseh carb
44 replies to this topic
#16 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 25, 2015 - 04:03 PM
Ok I got it running good..but seems like it doesn't rev up a lot.
#17 MH81 ONLINE
  • 29,438 Thanks
  • 29,544 posts
Posted July 25, 2015 - 06:02 PM
Max RPM's at 3400 for safety sake.
Did you make a tin?
  • Firefighter912 said thank you
#18 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 26, 2015 - 09:31 AM
I need to go find some. What kind of idea do you suggest? Running to through the carb bolt?
#19 MH81 ONLINE
  • 29,438 Thanks
  • 29,544 posts
Posted July 26, 2015 - 09:52 AM
If you look at the picture above, it will give you an idea.
It's the same thickness as the other tins. Any source you can
#20 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 26, 2015 - 11:00 AM
Ok I'll do my best.
#21 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
I ordered a baffle though.
#22 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 26, 2015 - 04:12 PM
What do you think about this for being temporary?
#23 MH81 ONLINE
  • 29,438 Thanks
  • 29,544 posts
Posted July 26, 2015 - 04:48 PM
Sure wont hurt until you find another one.
Anyone else see an issue?
#24 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 26, 2015 - 04:51 PM
Now my new belts are smoking at idle. Is this ok since they're new?
#25 MH81 ONLINE
  • 29,438 Thanks
  • 29,544 posts
Posted July 26, 2015 - 04:53 PM
Which belts?
#26 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 26, 2015 - 05:06 PM
Drive belt. I try to put it in neutral the belt wants to still turn but not like it does in gear.
#27 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 26, 2015 - 05:29 PM
Ok I have a question about each screw on the carb.
I'm assuming the bottom screw at bowl is the main adjustment, the one above the bowl is the low idle screw, the one near throttle shaft is the idle adjustment.
Right?
Does the top idle adjustment has to be adjusted?
#28 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 26, 2015 - 07:31 PM
The drive belt is pretty tight. Should it be since clutch is not pushed in?
#29 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted July 26, 2015 - 09:10 PM
Right?
It does have to be adjusted per engine to give you an idle fast enough to keep the engine cool.  Best way to adjust it is with a tach to really make sure it is right, unless you don't plan on idling it for long periods.
The other way you want it adjusted is so it will pick up from those low RPMS and get to the high (operating) RPMS without missing.  Tecumsehs usually want to be idling a little faster than other brands to do that right.
What model engine are you working on?
Ben W.
#30 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 26, 2015 - 10:05 PM
Hh100
Here are the videos of my belt smoking. What could be the issue?
