B112 wont shut off
3 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 23, 2015 - 02:41 PM
key switch style . starts great runs great ...wont turn off . tried another switch ( not a known working one ) and same results . not sure which wire is supposed to do it . is it the one hooked to the outside of the points cover ? I would put in a kill switch but I am not sure which wire to use .
any help would be great
#2 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,176 posts
Posted July 23, 2015 - 03:00 PM
If it has a separate starter button and uses a magneto then the key switch just grounds the points. I would bet that you have a broken wire. The wire from the points cover to the switch is the points grounding wire. Use an ohmmeter to check continuity from the points to the switch to find the break or corrossion. Good Luck, Rick
Check the wiring diagram in the manual.
Edited by boyscout862, July 23, 2015 - 03:01 PM.
  • TomLGT195 and alec have said thanks
#3 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 23, 2015 - 05:55 PM
thanks man !! got no reading from the points cover wire so I cleaned it up and put it back together and got close to zero . turned it on and tried to shut it off .... nothin..... then all of a sudden .. it dies ??  wiggled the key a little and tried again .. IT WORKS !!  messed with the key a little bit more and it works every time . thanks again
  • MH81 and boyscout862 have said thanks
#4 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,176 posts
Posted July 23, 2015 - 07:19 PM
You are very welcome. Remember, we are all in this together. Good Luck, Rick
  • alec said thank you
