* * * * - 6 votes
Project: LoBoy Custom
210 replies to this topic
#46 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,313 Thanks
  • 9,782 posts
Posted October 01, 2015 - 12:49 PM
That Volvo instrument cluster would look nice on an oak or walnut dash.
  • tiretrx said thank you
#47 tiretrx OFFLINE
tiretrx
  • 2,262 Thanks
  • 1,223 posts
Posted October 01, 2015 - 01:03 PM
Zackly, Rich :thumbs: Perhaps cherry.
Wood as you know was quite prevalent with the old machines, so we'll be using some. We already have a wood steering wheel. A bit modern, but we'll "age" it. Also, we discussed the seat being leather and wood. Bit of new territory, but we'll learn as we go.
  • Leonard VanCamp said thank you
#48 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 01, 2015 - 01:16 PM
i cant wait to see how this turns out im liking the way its going so far
  • tiretrx and michael.kitko have said thanks
#49 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted October 07, 2015 - 08:29 PM
This a sweet build, cant wait to see update pics!
#50 tiretrx OFFLINE
tiretrx
  • 2,262 Thanks
  • 1,223 posts
Posted October 08, 2015 - 09:28 AM
Right now I'm trying to cobble material for the front/rear hubs. I'll have to fabricate both as they need to adapt to the Model A rims. Also the back ones will have to extend 5" to make up the difference, front to back.
This is a rear set I made for a previous project. Pretty much the same idea at work.
Here's the fronts I made for that also.
I don't like buying material, and try to use what's lying around. Right now, I've got about 2/3 of the stuff I need. I have a buddy who hordes pieces of metal, so I'm going to visit his stash this weekend. Once I get the hubs done then I'll have the final stance and I can get to the real fun stuff, like the sheet metal, etc. Most of that stuff I already have.
Thanks for looking, I appreciate! :thumbs:
  • olcowhand, MH81, Alc and 5 others have said thanks
#51 olcowhand OFFLINE
  • 41,193 Thanks
  • 31,428 posts
Posted October 08, 2015 - 11:57 AM
Man you do some nice work!  I cobble things together, but my cobbling looks nowhere even close to the quality of yours.  I wouldn't classify any of your work by calling it "cobbled.   Great thread/project to follow!
  • Alc, KennyP, tiretrx and 1 other said thanks
#52 tiretrx OFFLINE
tiretrx
  • 2,262 Thanks
  • 1,223 posts
Posted October 08, 2015 - 12:18 PM
Thanks, I appreciate the kind words. I'm lucky to have tools to work with, and I really like building stuff. This one will take a bit, but it'll be fun getting there. Just can't wait till it rolls in the now, though.
  • olcowhand, Alc and KennyP have said thanks
#53 KennyP ONLINE
  • 38,385 Thanks
  • 45,935 posts
Posted October 08, 2015 - 05:50 PM
Those hubs are great! I'm with Daniel, no cobbling there!
#54 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 08, 2015 - 06:21 PM
No wonder you quit being an administrator, you could eek out a living making stuff out of metal.    :poke:
#55 tiretrx OFFLINE
tiretrx
  • 2,262 Thanks
  • 1,223 posts
Posted October 09, 2015 - 12:14 AM
Thanks a lot. I've really enjoyed following your build, great stuff.
Lol. You're a real turd, you know that, right?  :smilewink:
Edited by tiretrx, October 09, 2015 - 12:15 AM.
  • KennyP, Cat385B and LilysDad have said thanks
#56 tiretrx OFFLINE
tiretrx
  • 2,262 Thanks
  • 1,223 posts
Posted October 16, 2015 - 09:47 AM
........a bit more progress. I use these washers at work for certain ship parts. 8" OD x 3" ID x 5/16" thick. Model A pattern, five holes on a 5-1/2" bolt hole circle. Drilled and tapped on the lathe.
20151016_100834_zpswieoqw66.jpg?14450055
Fit nice.
20151016_102012_zpsewyha8n7.jpg?14450055
Next will be the plates to fit the LoBoy hubs.
  • olcowhand, Alc and Cat385B have said thanks
#57 Jimkemp OFFLINE
Jimkemp
  • 223 Thanks
  • 135 posts
Posted October 18, 2015 - 10:01 AM
Nice work on those hubs , I will keep watching
#58 tiretrx OFFLINE
tiretrx
  • 2,262 Thanks
  • 1,223 posts
Posted October 18, 2015 - 11:32 AM
Thanks Jim!
#59 tiretrx OFFLINE
tiretrx
  • 2,262 Thanks
  • 1,223 posts
Posted November 02, 2015 - 10:22 AM
Ok, now for some of the good stuff. Metal chips leaving their prior living spaces!
Finally, secured the main components necessary to start machining the front and rear hubs. The front hubs will be made from aluminum, bronze and stainless. The main driving forces there are that I have the pieces available, so I'm working the design backwards from that. The main three components are the aluminum outer flange which will bolt to the Model A rims, the inner stainless sleeve that rides on the spindle, and a bronze adapter to connect the two.
One of the parts we make are called deck boxes. They flush mount to ship/barge/rig walls or floors and allow for valve actuation. They are made of cast magnesium bronze and finish machined. We had a couple go to scrap recently, so I utilized a portion for the hub adapter.
Scrap piece.
20151027_134401_zpsobvbxs3p.jpg?14464728
Parted the top off to use.
20151027_134322_zps7zgxchlg.jpg?14464728
Turned to final shape.
20151028_084350_zpsbxxqpz8y.jpg?14464728
Drilled to connect to aluminum flange. One component down.
20151030_135043_zpsqgcb5mym.jpg?14464728
For the outer flange I had two scrap pieces of aluminum plate. They measured 1" thick x 8" OD as luck would have it. Turned the OD to 7-3/4" and the ID to 2-1/4" to fit over the adapter nose. This will require a lot more work.
Here's a simple 1/1 scale drawing I did on graph paper. It shows a cross section of the outer flange and adapter. The inner sleeve is not shown yet. Also shown are the 1/2"-20 threaded holes for the lug studs.
20151102_081538_zpsim5d9vqs.jpg?14464728
  • LilysDad said thank you
#60 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted November 02, 2015 - 12:50 PM
I found this by accident because it is in the custom tractor forum...may I just say...as stated above...D*** you do some nice work, and I can't wait to see how this turns out. Following.
