Vote for Tractor of the Month
* * - - - 1 votes
Project: LoBoy Custom
135 replies to this topic
#16 tiretrx ONLINE
tiretrx
  • 1,068 Thanks
  • 739 posts
Posted July 27, 2015 - 11:43 AM
Got some done this weekend. Not as much as hoped, but some. Basically, some more tear down, and a LOT more noodling.
Fenders, pan, seat and shaft shroud gone. PTO soon to follow.
20150726_182729_zpsfvtnm2wg.jpg?14380150
20150726_182744_zpsbj5hk6hy.jpg?14380150
This is one cluttered engine area. Needs changing.
20150726_182654_zpsdr6hopei.jpg?14380150
20150726_182714_zpsb3mtxqlp.jpg?14380150
Long way to go, but I'm liking this general profile.
20150726_182622_zpslrfkhlcx.jpg?14380150
  • Alc and Cat385B have said thanks
#17 Cat385B ONLINE
    Therapy CAT
  • 12,132 Thanks
  • 9,113 posts
Posted July 28, 2015 - 08:34 PM
Might the hydraulic system need a flushing? That filter looks modified..........
  • tiretrx said thank you
#18 MH81 ONLINE
  • 28,031 Thanks
  • 28,965 posts
Posted July 29, 2015 - 06:38 AM
On my FIL's old one, the clutch was right under the family jewels. Changed it once and the PTO Bearings for him. Told him after that job, I no longer liked his little tractor.
Glad your clutch isn't back there on this one.
#19 tiretrx ONLINE
tiretrx
  • 1,068 Thanks
  • 739 posts
Posted August 06, 2015 - 08:58 AM
Ok, back to beeness. More tear down on the LB. Wiring was a bear. Steering tower.......yeesh! But we got some "bones" now.
Rear view. Note the brace across the tranny top. Not stock. Sat on short pipes and there were nuts welded to frame rail tops.
20150805_171739_zps9r9oke2q.jpg?14388671
20150805_172443_zps5rbw8iay.jpg?14388671
Another point of interest. If you look below the bolt to right, you'll see weld on top, and on the side of the frame rail. Crack repair. The weld has failed on the lower portion and there is a crack.
20150805_171447_zpsuvotgytk.jpg?14388671
Steering/flywheel area.
20150805_171757_zpscuvrvqt7.jpg?14388671
It can breath!!! Beautiful. isn't it?
20150805_171610_zps2kw7egv3.jpg?14388671
This area is very cool to me. The castings, the mechanicalness. The fan!
20150805_171651_zpsftzktmwt.jpg?14388671
So after more noodling, I've realized I've been lying to myself when I thought "mild" custom. It will change a fair amount. I want to put the hood, grill and gas tank from a Cub on this puppy. See it peaking through in the photo above? That will be the focus in the immediacy. Then we build from there. Stay tuned :thumbs:
  • Alc and Paulgo have said thanks
#20 tiretrx ONLINE
tiretrx
  • 1,068 Thanks
  • 739 posts
Posted August 10, 2015 - 10:38 AM
Got a good block of time in with the LB Custom. The point of focus was the engine area. More particularly the fan/radiator set up.
This is where we started.
20150805_171651_zpsftzktmwt.jpg?14392197
My goal is to drop the radiator. And stretch it out. First, I flipped the top fan pulley. This thing is a hunk of humanity. Even the belt cone is cast iron. It weighed in at 10-1/2 lbs.! After the flip. Note that this keeps the pulleys in line.
IMG_20150808_113730_zpsrumdzew5.jpg?1439
To stretch the radiator placement I will use a spacer between the fan and pulley. This will eventually to made of aluminum. I didn't have the size needed in stock, so I turned a proto from brass for now.
The move came with the added benefit of getting the starter/gen more "outboard". Where it can be seen and not block the engine view. Plus, the belt still fits!
IMG_20150808_114444_zpsecsevj5n.jpg?1439
A bit of trimming on the radiator mounting brackets and that allowed to drop it to the proper place in between the frame rails  :D
IMG_20150808_121858_zpsu3cpncsq.jpg?1439
IMG_20150808_122221_zpstzxmvknj.jpg?1439
New look here. Went 2 inches forward and dropped 2-3/8". This sets up things for the look that I'm going for.
IMG_20150808_152047_zpsi01ofe4k.jpg?1439
#21 tiretrx ONLINE
tiretrx
  • 1,068 Thanks
  • 739 posts
Posted August 11, 2015 - 12:30 PM
Some pics of the brass fan spacer machining process. This is the proto, final will be lightweight aluminum.
20150807_132837_zpspuzdfpxo.jpg?14393111
20150807_141203_zpstxkue5nt.jpg?14393111
20150807_141929_zpsqxqm3bkw.jpg?14393111
20150807_142104_zpspzxfd84l.jpg?14393111
20150807_152219_zpswyuip6ka.jpg?14393111
20150807_153059_zpspunsnjua.jpg?14393111
20150807_155136_zpsrjncydpp.jpg?14393111
This is one heavy unit........for now. Anyone in the market for a real expensive brass paperweight in the near future?
20150807_155408_zps7avlkp9b.jpg?14393111
Suh-weet!
IMG_20150808_113726_zps2wfhcxla.jpg?1439
  • olcowhand said thank you
#22 Cat385B ONLINE
    Therapy CAT
  • 12,132 Thanks
  • 9,113 posts
Posted August 11, 2015 - 01:31 PM
I know the brass will have to go, but I really like the look. It's got 'bling'.
#23 tiretrx ONLINE
tiretrx
  • 1,068 Thanks
  • 739 posts
Posted August 11, 2015 - 01:44 PM
I really like the look also, Scott. The thing is, the pulley cone and the mounting bracket are both cast iron and weigh 10-1/2 lbs.!! The brass is also really heavy, and the weight that far out can't be good for the spindle/bearings.
#24 Cat385B ONLINE
    Therapy CAT
  • 12,132 Thanks
  • 9,113 posts
Posted August 11, 2015 - 01:48 PM
Are you set up to copper clad that aluminum? Hee hee!
#25 tiretrx ONLINE
tiretrx
  • 1,068 Thanks
  • 739 posts
Posted August 11, 2015 - 02:42 PM
No, but I got a paint set for Christmas :rocker2:
#26 tiretrx ONLINE
tiretrx
  • 1,068 Thanks
  • 739 posts
Posted August 12, 2015 - 08:27 AM
Whew doggie, had some fun last night. Spent so much time in the shop last night..............I almost missed the school bus this morning :D
Anyhoo, it all started with a desire to get the radiator supports in there new home, so the rad could be fully supported.
The supports.
IMG_20150811_180909_zpsw20dpouy.jpg?1439
They use to be bolted to the top of the frame rails. But with the rad lowered and set forward it was time for the point of no return.......cutting steel!!! (Darth Vadar approaching music)
So, after sharpening my sharpie, and some careful measurements, the sacrificial steel was determined.
IMG_20150811_182048_zpscyun6rd9.jpg?1439
Nestled in it's new home. Trued and clamped up.
IMG_20150811_184304_zpsw8taygbh.jpg?1439
Hard tacked and radiator bolted up.
IMG_20150811_200111_zpsyt6oyijx.jpg?1439
Done deal.
IMG_20150811_200129_zpssw1rk1pn.jpg?1439
Now's when things got creative. The "work" was done. Time to noodle. Noodle time is usually filled with small, ancillary accomplishments. Grinding, smoothing, lubricating, cleaning etc. The focus of my thoughts was the transition from grill to dashboard. More to the point, the lines I want at the end of the day. After some cutting, grinding and a bit of coercion, I fitted a late forties Cub hood/tank/dash on the LB. This is where the night ended........plenty of food to noodle :fing32:
IMG_20150811_235201_zps7yqeohcf.jpg?t=14
  • olcowhand, Alc, CRFarnsworth and 1 other said thanks
#27 shorty ONLINE
shorty
  • 3,916 Thanks
  • 4,221 posts
Posted August 13, 2015 - 06:01 PM
It is looking much different. Great to follow your progress.
#28 tiretrx ONLINE
tiretrx
  • 1,068 Thanks
  • 739 posts
Posted August 14, 2015 - 07:39 AM
Thanks, I appreciate it :thumbs:
Waiting on a couple pieces for the grill area. Probably work on the gas tank this weekend. It's going to be much shorter. Right now it's blocks the engine view too much. Besides that, it just won't be running for stretches long enough to need the present capacity.
  • MH81 and shorty have said thanks
#29 tiretrx ONLINE
tiretrx
  • 1,068 Thanks
  • 739 posts
Posted August 15, 2015 - 06:30 AM
No new "build" news from last night. Just some mocking up and measuring. Bringing in some parts I had squirreled away.
Figure it might be time to share where the "vision" is headed on this build. I like to tie the automotive to the tractor in both look and function. After mocking up the old Cub hood, it just dawned on me........this is called a LoBoy. One of the coolest rides ever was the Lowboy
I plan on borrowing from the vibe, not copying it. Some mock up along those thoughts.
How cool is this?
  • olcowhand, Alc, CRFarnsworth and 4 others have said thanks
#30 Austen ONLINE
Austen
  • 891 Thanks
  • 587 posts
Posted August 17, 2015 - 03:21 PM
Looking good there, Ellis! What type of tires are you planning to run?
Edited by Austen, August 17, 2015 - 03:21 PM.
