Drug home another ih truck
17 replies to this topic
#1 nbent OFFLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted July 22, 2015 - 11:01 PM
Just like the title says after I sold my road grader I went looking for another project to do. After just a little searching I found this uploadfromtaptalk1437623485924.jpg its a 1959 international R-190. When I got it the engine was stuck but it had diesel sitting in the cylinders for at least ten years. After we got it out of the hole it made in the 30+ years it had been sitting we got it on the road heading home and found it has no clutch but it broke free easy. Once home we started getting stuff to see if it would run and after two hours it was driving under its own power. Still a lot to be done I need the air filter bottom and the battery box cover plus see if the fuel pump works. uploadfromtaptalk1437623964792.jpg uploadfromtaptalk1437623975798.jpg uploadfromtaptalk1437623986664.jpg It has a 450 straight six powering this beast coupled to a 5 and 4 transmissions plus air brakes all the way around that surprisingly function more pics to come
  • Gtractor, grnspot110, Alc and 14 others have said thanks
#2 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted July 22, 2015 - 11:05 PM
That is a clean IH you picked up. Not surprising seeing you are in Utah. Very nice score.
  • Lmiller3358, boyscout862 and Marty'70 have said thanks
#3 KennyP ONLINE
  • 40,236 Thanks
  • 46,811 posts
Posted July 23, 2015 - 04:25 AM
Looks pretty straight too! Glad you got it running!
#4 Lmiller3358 ONLINE
Lmiller3358
  • 1,534 Thanks
  • 1,448 posts
Posted July 23, 2015 - 04:28 AM
Cool, Dad had a '59 R 200 same 450  5 and 3 and 2 speed rear end,,,if it was an R 220 diesel I would have kept it,,,he had an R 190 also, I think that was a '57,,, good look with it, the ten wheelers are rare
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted July 23, 2015 - 06:59 AM
Being a tandem makes it really nice.
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 23, 2015 - 10:23 AM
Real nice! I can't believe it sat for 30years and is still in that condition. Is a 450 a 450CI 6? That's a big 6!!
#7 Marty'70 ONLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 868 Thanks
  • 722 posts
Posted July 23, 2015 - 01:31 PM
Yeah! If that had been here in PA there wouldn't have been much left of it..
  • wvbuzzmaster said thank you
#8 nbent OFFLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted July 23, 2015 - 04:39 PM
Yes that's 450 ci they also made a 501 for these trucks. I have been debating on whether to leave the gas engine in or find a diesel to put in it. Here is another pic of it uploadfromtaptalk1437687559763.jpg
  • Gtractor said thank you
#9 KennyP ONLINE
  • 40,236 Thanks
  • 46,811 posts
Posted July 23, 2015 - 06:25 PM
How many GT's will it hold?
#10 nbent OFFLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted July 23, 2015 - 09:38 PM
It's a 15 x 7.5 bed so it should hold a few I plan on changing it to a steel bed with a dove tail
#11 adamjd200 OFFLINE
adamjd200
  • 2,088 Thanks
  • 2,203 posts
Posted July 23, 2015 - 10:02 PM
I'd go with swapping in a diesel, my dad drove a gas job in PA in 2006,2007, and 2008, got about 2mpg the diesels were getting 6-8mpg.
  • Alc and toomanytoys84 have said thanks
#12 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,543 Thanks
  • 6,199 posts
Posted July 26, 2015 - 11:00 AM
2mpg? My gosh. You'd give a Prius owner a heart attack!
#13 Jazz ONLINE
Jazz
  • 2,604 Thanks
  • 1,525 posts
Posted July 26, 2015 - 03:42 PM
Nice truck but if you are planning on putting it to use the Red Diamond will need 4 mpg when hauling....downhill.  I would repower with a 466DT.,,,10mpg or better but then you also have to change gear ratios in axle...so you have to decide how committed you are...good luck!
Parts are available but not real common for the Red Diamond. I see older diesel powered S-lines frequently cheap and less work to roll a complete chassis and drive train under your existing body...JMHO
Edited by Jazz, July 26, 2015 - 03:46 PM.
#14 adamjd200 OFFLINE
adamjd200
  • 2,088 Thanks
  • 2,203 posts
Posted July 26, 2015 - 10:10 PM
Big 500+ci V8, could only use high test also
  • Austen said thank you
#15 nbent OFFLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted August 07, 2015 - 11:45 AM
Well not any work going on just going through the headache to get the title
  • KennyP and Cvans have said thanks
