Hydrostatic drive efficency
27 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,360 Thanks
  • 5,605 posts
Posted April 05, 2011 - 04:57 PM
OK here's a question for those who know and if I knew the answer I wouldn't be asking the question.
How efficient is a Hydrostatic drive system in delivering power?
My understanding is basically a gas or diesel engine drives a hyd pump that supply's fluid pressure through control vales and hoses to a hyd motor that drives the trany, moves the tractor.
So if an engine has 10hp or 20hp, whatever # you want to use, at the crankshaft then how much HP is at the Hyd motor's shaft?
10hp in how much out?
#2 olcowhand ONLINE
  • 42,348 Thanks
  • 31,787 posts
Posted April 05, 2011 - 05:43 PM
What you described is hydraulic drive, not hydrostatic. Hydrostatic involves a piston pump with variable flow rate, and a fixed displacement piston motor. Hydraulic drive is a fixed displacement gear pump, with a valve to vary the amount of oil to flow to the gear motor in order to change speed.
With hydrostatic the power loss is somewhere around 20% give or take, depending on particular unit. So a 10hp engine can only put about 8hp to the ground, maybe a tad more.
  • nra1ifer, MH81, Alc and 3 others have said thanks
#3 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted April 05, 2011 - 06:24 PM
I was going to say it would be at least a 15% - 20% loss. Dan hit the nail on the head with his description :D
  • middleageddeere said thank you
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,360 Thanks
  • 5,605 posts
Posted April 05, 2011 - 08:18 PM
So which of those 2, Hydrostatic vs Hydraulic in general would be more efficient in terms of delivering power?
#5 olcowhand ONLINE
  • 42,348 Thanks
  • 31,787 posts
Posted April 05, 2011 - 08:26 PM
I had to look up hydraulic drive efficiency, but after finding this here: The Next Challenge For the Maintenance Department
It would appear hydrostatic wins by a good margin over gear hydraulic pump drive. Hydraulic loses 40 to 50% to hydrostatic loss of around 20%.
  • ducky, Texas Deere and Horse, IamSherwood and 1 other said thanks
#6 DH1 ONLINE
DH1
    Electric Tractors
  • 5,360 Thanks
  • 5,605 posts
Posted April 05, 2011 - 08:37 PM
Then I guess that's why they use Hydrostatic over Hydraulic drive.
And I guess that's why Hydro's in general don't do so well in pulling tractors, a strong Hydro pulling tractor needs a more powerful engine.
I see in your link they mention pump losses and motor losses is that the case here with Hydrostatic drive?
Is the 20% loss total or for each pump+motor?
#7 olcowhand ONLINE
  • 42,348 Thanks
  • 31,787 posts
Posted April 05, 2011 - 08:41 PM
Yes, the losses is for the entire system, pump & motor, plus valve losses & such. Hydrostatic might even go down to 75% efficiency, but still way ahead of hydraulic drive.
  • DH1 and Texas Deere and Horse have said thanks
#8 DH1 ONLINE
DH1
    Electric Tractors
  • 5,360 Thanks
  • 5,605 posts
Posted April 05, 2011 - 08:46 PM
OK no more questions I found out what I wanted to know. Thanks
#9 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted April 06, 2011 - 05:53 AM
How do those numbers compare to loss on gear drives?
#10 TUDOR OFFLINE
TUDOR
  • 565 Thanks
  • 507 posts
Posted April 06, 2011 - 06:23 AM
Efficiency ratings of hydraulic pumps and motors.
Piston - 90%
Vane - 85%
Gear - 75 -80%
For a pump/ motor combination
- Piston to Piston (.9 x .9) - 81%
- Vane to Vane (.85 x .85) - 72%
- Gear to Gear (.8 x .8 best case) -64%
- Gear to Gear (.75 x .75 worst case) - 56%
- Piston to Gear (.9 x .8 MF12H) - 72% or 68% using the lower number , but Sundstrand has pretty good equipment.
Wear can change things , but these are the theoretical numbers used for basic design of a system.
  • NUTNDUN, olcowhand, DH1 and 4 others have said thanks
#11 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 06, 2011 - 07:50 AM
That's quite a loss in the hydraulic system. Had know idea.
#12 olcowhand ONLINE
  • 42,348 Thanks
  • 31,787 posts
Posted April 06, 2011 - 08:58 AM
I knew Tudor would have all the figures! Thanks Tudor!
#13 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted April 06, 2011 - 10:10 AM
I am not real sure but I think the gear drives can range from 5% - 10% loss depending on how efficient they are. The more gears, bearings and shafts that the power gets transmitted through more loss there will be. Would be great to know what the efficiency loss would be say per gear tooth width, bearing surface area and what not. I am sure the figures are out there somewhere but I don't know the mathematical equations to figure it all out :D
#14 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 06, 2011 - 10:26 AM
Not to be argumenitive but with that considered. What makes the Case/Ingersoll Gt's Hydralic Drive so admired and apreciated?
#15 olcowhand ONLINE
  • 42,348 Thanks
  • 31,787 posts
Posted April 06, 2011 - 10:31 AM
One is the fact they still make them as strong built as in the olden days. The other (my opinion anyway) is because they are so unique in their drive design.
