Case 210 gas tank removal.
5 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,022 Thanks
  • 2,151 posts
Posted July 20, 2015 - 01:23 PM
So I need to remove the gas tank from my 210 to clean the crap out of it before I can even think of trying to see if the old girl will start.  My question is, is there a way I can remove the tank without tearing the entire back of the tractor apart?
#2 boyscout862 ONLINE
  • 12,551 Thanks
  • 9,044 posts
Posted July 20, 2015 - 03:28 PM
Have you downloaded the manual? Good Luck, Rick
#3 adamjd200 OFFLINE
adamjd200
  • 2,022 Thanks
  • 2,151 posts
Posted July 20, 2015 - 05:21 PM
We don't have a service manual or owners manual here, just a parts manual, already looked.
#4 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted July 20, 2015 - 09:14 PM
It is not as bad job as it looks . Start with seat plate it's attached by the tool tray depending what tray it has if seat pin not in way take seat plate and tool tray together. Take one fender off all the way take back plate off then loosen other fender enough to raise tank out. Being careful of the gas fitting on bottom.
#5 adamjd200 OFFLINE
adamjd200
  • 2,022 Thanks
  • 2,151 posts
Posted July 20, 2015 - 09:29 PM
Ok, should be pretty easy then as there was no seat on it when I bought it, still looking for a correct one, have a seat that I'll adapt if not, one fender was removed when I got it also, (I do have it) so it wont take much.
#6 adamjd200 OFFLINE
adamjd200
  • 2,022 Thanks
  • 2,151 posts
Posted July 20, 2015 - 09:30 PM
Can anyone post a pic of the shift pattern for this tractor, my decal is partially unreadable.
