belt
11 replies to this topic
#1 joey7478 OFFLINE
joey7478
  • 3 Thanks
  • 54 posts
Posted July 20, 2015 - 11:33 AM
What size is starter gen belt on a 67 1614? lost other one while mowing and chopped it up. Thanks Joey!
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted July 20, 2015 - 11:35 AM
Wrapping a string around it will get you close.
  • joey7478 said thank you
#3 joey7478 OFFLINE
joey7478
  • 3 Thanks
  • 54 posts
Posted July 28, 2015 - 06:00 PM
out of 97 views surely some one has bought a belt this size or does no one want to help?
#4 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted July 28, 2015 - 06:48 PM
http://gardentractor...749-pk-belts-2/
ELECTRICAL - Check Starter Sheave 0.0. for Accuracy
Serial Number 5970 to 6973 09-0050
Serial Number 6974 to 8692 09-0051
Serial Number 8693 to 16853 81-0031
#5 Alc ONLINE
  • 6,885 Thanks
  • 7,461 posts
Posted July 29, 2015 - 05:44 AM
There's not a lot of forgiveness on the adjustments , You wouldn't want the ones on my Jim Dandy nor PK . both were almost too big when first put on
#6 joey7478 OFFLINE
joey7478
  • 3 Thanks
  • 54 posts
Posted July 29, 2015 - 10:45 AM
this dosen't show starter belt Thanks Joey!
#7 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted July 29, 2015 - 10:49 AM
Did you manage to salvage any of the chewed up belt? If its still fairly intact I may be able to help you, unless someone comes up with a part number.
Is this a regular v belt, or cogged belt common on most starter belts?
#8 joey7478 OFFLINE
joey7478
  • 3 Thanks
  • 54 posts
Posted July 29, 2015 - 10:55 AM
No it was so worn and chopped  up and it was a v belt.
#9 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted July 29, 2015 - 11:01 AM
These are all starter belt numbers.
According to your serial number and this chart,this should be your belt;  http://www.ebay.com/...-/151751819934?
#10 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted July 29, 2015 - 11:13 AM
Can you provide a pic of where this belt goes?
If The ebay one linked above is correct, the belt I would suggest to use today would be this one
https://bolenspartsa...-belt-171-4690/
or a Kevlar one if desired
#11 joey7478 OFFLINE
joey7478
  • 3 Thanks
  • 54 posts
Posted July 29, 2015 - 11:14 AM
sorry didn't see the numbers below the link.
#12 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted July 30, 2015 - 11:08 AM
You might pick up some business if you would cross reference your belts to the Power King belts.
