Wanted
Cub Cadet -- 6 to 8 inch pulley with 1 inch bore
1 reply to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted July 19, 2015 - 08:46 PM
Guys, I need some help, dig through your boxes of misc. pulleys and see if you can locate a pulley of approximately 6 to 8 inch diameter that fits a 1" diameter shaft. If it was a 3V pulley that is a bonus. What I need it for s my Cub Cadet 108 that I am eliminating the mower PTO on for two reasons. One being I have no PTO implements. The latter being the starter generator pulley / clutch basket is ruined. At some point the key way set screw fell out leaving it loose on the shaft, the set screw only bites into 2.5 threads... I want something more substantial moving forward. Any help would be appreciated. Thanks.
#2 MH81 OFFLINE
Posted July 20, 2015 - 06:31 AM
Casey, I will try to remember to look Tuesday nite when up there.
  • wvbuzzmaster said thank you
