bgb removal
9 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 19, 2015 - 06:49 PM
so I may need to dig into my bgb on a B112 . unfortunatly the po added a hydro lft pump to the mix and welded a plate to BOTH SIDES of the bgb plates :wtf: . its kinda cool how the setup works ( the lift handle is on the right hand side of the seat and the ram is on the right hand side of the frame  ) but good gravy man ! welding the bgb plates together ???? pretty sure I can cut the left side off and leave it unhooked being the belt goes on the left side for the pump and the pressure from the belt should keep it from going up . we shall see .
 I will add some picks soon ... guy welded stuff all over the place
p_00603.jpg p_00604.jpg p_00605.jpg p_00606.jpg p_00607.jpg p_00608.jpg p_00609.jpg B112.jpg
pretty weird huh ?245.jpg   oops thats my cat
Edited by alec, July 19, 2015 - 07:26 PM.
  • MH81, Alc, KennyP and 3 others have said thanks
#2 MH81 OFFLINE
Posted July 20, 2015 - 06:20 AM
Wow, there is a time and a place for permanent attachment and there is a time and place for brackets and bolts.
This guy was all out of bolts.
Neat setup, good luck getting the BGB out.
  • Alc and alec have said thanks
#3 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted July 20, 2015 - 06:30 AM
That should be fun!
  • alec said thank you
#4 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted July 20, 2015 - 10:31 AM
Nice cat, WTF is a BGB? (Never worked on an Allis Chalmers before)
#5 TAHOE ONLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted July 20, 2015 - 11:31 AM
Bevel gear box
  • MH81, TomLGT195 and alec have said thanks
#6 MH81 OFFLINE
Posted July 20, 2015 - 06:05 PM
Don't forget about the tech wiki
http://gardentractor...html/_/bgb-r114
http://gardentractor.../term_wiki.html
  • adamjd200 and alec have said thanks
#7 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted July 20, 2015 - 07:17 PM
Would of never thought of that lol, too much else on my brain.
#8 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 21, 2015 - 09:14 PM
that was fun ...NOT !! got the bgb out and apart . the screw on the drive shaft gear was hand tight and the keyway slot was warbled out . it was full of oil so I put another shaft in and put it back together . while I was putting the pulley on the left side I put it on to far and pulled it back and out came the shaft .... found the slot and pushed it back in and installed the drive pulley  seems okay . has a little slop but sounds quite and smooth .
#9 MH81 OFFLINE
Posted July 21, 2015 - 09:39 PM
Glad you got it done.
How many cutting discs did you go thru?
#10 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 21, 2015 - 11:20 PM
about a quarter of one . surprised the crap outa me ! lol
