craftsman 6500 garden tractor. Help
44 replies to this topic
#31 kpost OFFLINE
kpost
  • 6 Thanks
  • 15 posts
Posted July 21, 2015 - 08:12 PM
here -is the model 3 ps-sv735-0016
#32 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,454 Thanks
  • 5,764 posts
Posted July 21, 2015 - 08:35 PM
How hard is it to spin the engine by hand?
  • kpost said thank you
#33 kpost OFFLINE
kpost
  • 6 Thanks
  • 15 posts
Posted July 30, 2015 - 03:33 PM
just got a few moments of connectivity here.  the engine is turnable by hand and it it not that difficult.  It turns pretty easily until it builds up compression, then it is very hard.  sometimes at this point, i turn it the other way.  when the plugs are out of it, it turns easier.  thanks, kpost
#34 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,454 Thanks
  • 5,764 posts
Posted July 30, 2015 - 04:46 PM
With the plugs out it should easily turn around and around due to the lack of compression forces.  If it 'grabs' or gets harder to turn at any point I'd suspect cylinder wall/ piston issues.  So if that is the case, pull the head off and inspect..
Edited by WNYTractorTinkerer, July 30, 2015 - 04:46 PM.
#35 toppop52 OFFLINE
toppop52
  • 5,250 Thanks
  • 4,755 posts
Posted July 30, 2015 - 08:19 PM
I still think it's the compression release, due to valves or otherwise.
Edited by toppop52, July 30, 2015 - 08:20 PM.
#36 kpost OFFLINE
kpost
  • 6 Thanks
  • 15 posts
Posted August 03, 2015 - 03:30 PM
Ok, now that i am back i have a few questions for some of you.  WNY tractor tinker, How do i find out if it is a cylinder wall piston issue or not?  How do I go about pulling it apart?
Also, to toppop52, if it is a compression realease issue, how do i know and what do i do?
At this moment, the tractor kinda runs(as long as i twinkle my ears etc, i can get it started), but i am a little nervous about taking it apart. This is a little confidence issue with me, so please tell me what it is that i should do first.   thanks in advance, kpost
#37 kpost OFFLINE
kpost
  • 6 Thanks
  • 15 posts
Posted August 03, 2015 - 03:50 PM
I am trying to get a manual for my motor.  I am going to try to look one up here on this site,  Can anyone tell me what motor to look up?  I have already tried to look up ps-sv735-0016.  any help, kpost
#38 MH81 OFFLINE
Posted August 03, 2015 - 04:05 PM
Look at the Kohler engine manuals.
Yours will be close to the command in design (may be some differences)
#39 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,454 Thanks
  • 5,764 posts
Posted August 03, 2015 - 04:07 PM
http://kohlerengines...m_32_690_01.pdf
#40 kpost OFFLINE
kpost
  • 6 Thanks
  • 15 posts
Posted August 03, 2015 - 05:26 PM
Thank you very much.  I can read any language in the world, except Greek.  It all looked Greek to me.  thanks again anyhow.  kpost
#41 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,454 Thanks
  • 5,764 posts
Posted August 03, 2015 - 05:38 PM
Wellsboro..  I visited a friend of my mom's down in your burg when I was a wee tot..  We lived in Corning @ the time..
Sorry ti looks Greek to ya but it will give you all the info you need to do anything to that motor..
#42 toppop52 OFFLINE
toppop52
  • 5,250 Thanks
  • 4,755 posts
Posted August 03, 2015 - 07:14 PM
Verify if your motor has solid or hydraulic lifters, all solids and some hydraulic lifters, require adjustment. The Manual should tell you if and to what specs they are adjusted. Even if they are non adjustable hydraulics, there is some mechanism for compression release that has to function in order for the engine to spin at normal starting speed. Everything you describe sounds like compression load on start up.
#43 kpost OFFLINE
kpost
  • 6 Thanks
  • 15 posts
Posted August 08, 2015 - 07:50 PM
I just typed a whole bunch of data into this box and it all went some place.  Short story, I pulled the flywheel and put in a new pin,  It is working very well at this time. It did quit on me, but as of 20 minutes ago, it was starting up without all the otheIr things that i had to do.   I will keep you up to date if anything else goes wierd.  thanks for all the help.. kpost
#44 MH81 OFFLINE
Posted August 09, 2015 - 08:46 AM
Glad to hear the key was the issue.
Of all the issues, it was probably the overall easiest to repair.
Now, please let us know how you make out with Sears, getting a refund, and getting the letter of apology from that idiot.
#45 kpost OFFLINE
kpost
  • 6 Thanks
  • 15 posts
Posted August 09, 2015 - 08:15 PM
Ironically, it was the Sears fridge repair man that suggested a few things.   He was there to obviously look at the fridge, so i picked his head.  He seemed to know more about it than the other guy.  kpost
