lgt 14 D ford
15 replies to this topic
#1 alexbenton92 OFFLINE
alexbenton92
  • 18 Thanks
  • 14 posts
Posted July 17, 2015 - 05:55 PM
My ford lgt 14d diesel :)
  • boyscout862, Dieselcubmike, Chopperhed and 5 others have said thanks
#2 boyscout862 OFFLINE
  • 12,839 Thanks
  • 9,162 posts
Posted July 17, 2015 - 06:09 PM
Nice machine, tell us about it. Good Luck, Rick
  • Chopperhed and propane1 have said thanks
#3 propane1 ONLINE
propane1
  • 8,721 Thanks
  • 4,126 posts
Posted July 17, 2015 - 06:21 PM
I have wondered that if you had a garden tractor with a 14 hp gasoline engine with a 48" deck and was cutting two acres of grass and you had the same tractor with a Diesel engine, would the fuel consumption be less or more with the diesel ???? Pros and cons ? Noel
Nice looking tractor, very rare in my area.
Edited by propane1, July 17, 2015 - 06:32 PM.
  • boyscout862, Chopperhed and holdenboy1960 have said thanks
#4 alexbenton92 OFFLINE
alexbenton92
  • 18 Thanks
  • 14 posts
Posted July 17, 2015 - 06:36 PM
It doesn't use much fuel at all haha it actually surprised me. Its a 1987 14hp 48 in cut, hydrostatic
  • KennyP, boyscout862, Chopperhed and 3 others have said thanks
#5 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 17, 2015 - 06:41 PM
You'd use less, while having more torque.  You typically get more bang for your buck with diesel.  Diesel engines typically last longer and require less maintenance but are often harder to start.  Diesels sound better imo but are known for being louder than similar gas engines.
  • boyscout862, Chopperhed, propane1 and 3 others have said thanks
#6 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted July 17, 2015 - 06:54 PM
That is a very nice looking tractor!
  • boyscout862 and Chopperhed have said thanks
#7 alexbenton92 OFFLINE
alexbenton92
  • 18 Thanks
  • 14 posts
Posted July 17, 2015 - 06:56 PM
Thank you
  • Chopperhed said thank you
#8 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted July 17, 2015 - 07:49 PM
Agreed. It's a fine looking piece of equipment.
#9 javjacob OFFLINE
javjacob
  • 37 Thanks
  • 29 posts
Posted July 18, 2015 - 01:07 AM
Very nice tractor! You don't see them around where I live very often. My neighbor has a LGT 16D but its in pretty rough condition.
  • propane1 and holdenboy1960 have said thanks
#10 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted July 18, 2015 - 07:37 AM
NICE!
#11 alexbenton92 OFFLINE
alexbenton92
  • 18 Thanks
  • 14 posts
Posted July 18, 2015 - 07:45 AM
This one wasnt real bad when I got it, all I mainly had to do was strip it apart and clean real good and paint.
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 19, 2015 - 09:40 AM
[quote name="middleageddeere" post="592153" timestamp="1437176501"]You'd use less, while having more torque.  You typically get more bang for your buck with diesel.  Diesel engines typically last longer and require less maintenance but are often harder to start.  Diesels sound better imo but are known for being louder than similar gas engines.[/quote
I agree completely! My 20 hp Ford 1500 pulling a 5 ft brush hog mower burns less fuel per hour than my 318' 22 hp Poulan Pro. Or my 22hp Murray rail frame.
Yes that 2 cyl diesel is louder, but other than fuel and oil it requires little maintainence.
I had a couple of times the first winter it was hard to start.
But once I learned to keep the battery in top shape and fuel treated in winter, it never fails.
  • propane1 said thank you
#13 Mike Brooks OFFLINE
Mike Brooks
  • 1 posts
Posted August 09, 2015 - 09:24 PM
Does anyone know of a mower deck for sale for the LGT 14D? Or are there other brands out there that would be compatable?
Currently in the process of striping mine down for paint and fix a few things. But im just missing the deck to have a complete set up.
All im able to do with it right now is push snow. would like to find a deck and use it to mow again.
Thanks Guys
#14 gksyn OFFLINE
gksyn
  • 85 Thanks
  • 89 posts
Posted June 28, 2016 - 08:48 AM
How's it running?! Still have the 14D Diesel?!
#15 Alexbenton OFFLINE
Alexbenton
  • 1 posts
Posted July 13, 2016 - 10:28 PM
It's running good thankz for asking, I'm in the process of changing the bearings in the deck now. All the nuts and bolts have almost become one piece with the deck haha
