* * * * * 1 votes
Sears rectifier
65 replies to this topic
#61 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 25, 2015 - 09:21 AM
Ok, I'm slow a little.
1)Battery (+) to Solenoid
2)Battery (+) to 20 amp fuse to B terminal on switch
3)Wire from the one post on solenoid to S terminal on key switch
4)Rectifier hot wire (12 v) to 20 amp (maybe less?) Fuse to L terminal on key switch
5)Magneto wire to M terminal on switch as before
6)Run ground wire to G terminal on switch
7)Crank it up. Check the ground to make sure nothing is shorting out.
8)Have hot wire from battery run to inline fuse then to the Light switch. Have ground run to the G terminal on key switch?
Sound about right?
#62 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,464 Thanks
  • 4,580 posts
Posted July 25, 2015 - 09:39 AM
Don't think you need the (G) Ground to the switch. This is usually for a kill wire for non-point magnetos.
#63 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 25, 2015 - 09:40 AM
10-4.
I dont have points from what I know.
#64 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 25, 2015 - 09:47 AM
Well the key switch is mounted in the fiberglass dash so it has to have a ground. Just remembered
#65 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,464 Thanks
  • 4,580 posts
Posted July 25, 2015 - 10:32 AM
Based on the diagram you posted at the beginning it shows points. You need to know which you have.
Points / Coil, the kill is accomplished by removing power to the (I) terminal (Ignition)
For a Magneto, the kill is accomplished by grounding the (M) terminal (Magneto)
You will fry a magneto if you apply power to the kill wire.
#66 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 25, 2015 - 11:09 AM
Ok well I got the magneto to the M terminal...so far it's throwing out spark.
Main thing was my carb was shot and I couldn't keep engine running. Got a new carb now.
