* * * * * 1 votes
Sears rectifier
65 replies to this topic
#1 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 16, 2015 - 06:56 PM
I'm getting 12.43 or so volts from the middle rectifier wire When the tractor is running. The wire suppose to run to the battery. So if I hook it directly to battery it should be fine?
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted July 16, 2015 - 07:57 PM
At what RPM, I get almost 14V on mine at 1/3 throttle, after I grounded the regulator case to the chassis. The regulator output needs to go through the key switch, Otherwise you will kill the battery when not running.
Edited by larrybl, July 16, 2015 - 07:58 PM.
#3 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 16, 2015 - 08:07 PM
So the hot wire from rectifier goes through switch? Diagram just shows it following it to hot post on battery?
#4 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted July 16, 2015 - 08:21 PM
OK, Most I have worked on goes through the SW. If the diagram is correct, follow it.
Edited by larrybl, July 16, 2015 - 08:24 PM.
#5 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 16, 2015 - 08:23 PM
Thanks. Making sure it was right. We'll find out
#6 TAHOE ONLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted July 16, 2015 - 08:38 PM
If you got straight to the battery, there is a chance it can drain the battery as it sits. Mine all go through the ignition terminal on the switch
Edited by TAHOE, July 16, 2015 - 08:39 PM.
#7 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 16, 2015 - 08:40 PM
To the battery terminal or what?
#8 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted July 16, 2015 - 08:41 PM
I noticed there is no fuse in your diagram. EVERYTHING I have ever worked on has a fuse. What model sears is this? So I can make sure NOT to get one. One short and the whole thing will go up in smoke.
#9 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 16, 2015 - 08:42 PM
1971 sears custom 10xl
#10 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted July 16, 2015 - 08:43 PM
Looked at that wiring diagram and there isn't a fuse shown ? Also you can turn the headlights on without the key being on .
#11 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted July 16, 2015 - 08:44 PM
Post the model # and I'll see if I can find the correct diagram. The one you posted doesn't look right.
The 917.XXXX number
Edited by larrybl, July 16, 2015 - 08:45 PM.
#12 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted July 16, 2015 - 08:55 PM
917.253060
#13 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Ot 917.25590
#14 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted July 16, 2015 - 09:22 PM
Your diagram looks correct. Version "C" in this manual. http://gardentractor...iring-diagrams/
#15 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted July 16, 2015 - 09:25 PM
917.253060          look at C
917.25590          look at K
Both look the same
