Front axle slop on narrow frame
4 replies to this topic
#1 lrhredjb ONLINE
lrhredjb
  • 700 Thanks
  • 573 posts
Posted July 16, 2015 - 10:10 AM
I noticed a while back I have some slop fore and aft on the 106 front axle. Should I care about this and if so could I just insert a washer to take up the excess room in the frame slot for the axle?
#2 olcowhand OFFLINE
  • 41,269 Thanks
  • 31,447 posts
Posted July 16, 2015 - 10:16 AM
Yes, I'd just shim it with a washer.  That slop translates to more steering play.
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted July 16, 2015 - 10:55 AM
Better to repair now before it gets excessive.
#4 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted July 16, 2015 - 01:46 PM
My 108 wide frame has slop. Im not ready to mess with it. I just went thru the steering on it and it now goes where i ask it to lol.
#5 IHCubGuy OFFLINE
IHCubGuy
  • 1,537 Thanks
  • 1,601 posts
Posted July 16, 2015 - 06:18 PM
Get rid of the pin that it came with.  Get a 3/4" grade 8 bolt with a nylock nut and draw it down till the slop is taken up.  Problem solved!  I have done this to my 100 and my 107.  The 100 has had it on for 6 years now and is as tight as the day I did it.  I also center drill the bolt and put a grease zerk in the end to grease the axle.  Some have a zerk on the axle pivot and are already greasable.  Hope this helps.
Edited by IHCubGuy, July 16, 2015 - 06:18 PM.
  • wvbuzzmaster said thank you
