Why is it Vapour Locking?
19 replies to this topic
  • 2,325 Thanks
  • 1,496 posts
Posted July 13, 2015 - 02:37 PM
I have a generator with a Tecumseh engine.  It keeps vapour locking on me.  I purge the fuel line before starting, but slowly bubbles start to form & work their way up to the shutoff valve, but they won't go past it into the tank.  Within 15 minutes, the fuel line is full of fuel vapour (or air) & the engine stalls. The gas cap works & it does it whether the cap is on or off.  I have installed a piece of garden hose as a temporary heat shield, but that hasn't helped.  Any ideas on where to go from here?
  • MH81, hamman, boyscout862 and 1 other said thanks
#2 propane1 OFFLINE
propane1
  • 8,458 Thanks
  • 4,034 posts
Posted July 13, 2015 - 02:52 PM
Would the carb float bowl vent be blocked. Float bowl needs air to operate. When the needle opens to let gas in, the air in the bowl is going back up to the tank, to allow gas into the bowl, until needle shuts it off again. If the bowl was vented it would allow air out of the bowl, to allow gas in. Just a guess,  Noel
  • MH81, Alc, hamman and 1 other said thanks
#3 DougT ONLINE
DougT
    Dog Approved
  • 6,853 Thanks
  • 4,953 posts
Posted July 13, 2015 - 03:09 PM
Have you pulled the shut off valve out of the tank and made sure it isn't partially clogged?
#4 boyscout862 ONLINE
  • 12,535 Thanks
  • 9,034 posts
Posted July 13, 2015 - 03:34 PM
First, great pics! I agree with DougT that I suspect that the valve is partially plugged. Some of them have a screen to catch junk. I like the old sediment bowl under the tank so that you can see any dirt or water. Good Luck, Rick
My wife's MTD kept dying on Saturday because the fuel line collapsed.
Edited by boyscout862, July 13, 2015 - 03:36 PM.
  • hamman and New.Canadian.DB.Owner have said thanks
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,974 Thanks
  • 9,616 posts
Posted July 13, 2015 - 03:40 PM
In the very first picture, it almost looks like the bend in the hose is higher than the barb on the inlet. Do you have one that points down?
  • MH81, hamman and New.Canadian.DB.Owner have said thanks
#6 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,360 Thanks
  • 2,837 posts
Posted July 13, 2015 - 04:24 PM
Just redid the fuel line on a snowblower that had collapsed inside.  Fuel filter going right way?  Just a WAG ! Good luck.                                           Roger
  • boyscout862, New.Canadian.DB.Owner and propane1 have said thanks
#7 dodge trucker ONLINE
dodge trucker
  • 2,297 Thanks
  • 3,014 posts
Posted July 13, 2015 - 05:16 PM
what is "vapour"  I know what "vapor" is....
#8 chieffan ONLINE
  • 9,564 Thanks
  • 6,406 posts
Posted July 13, 2015 - 05:56 PM
Same thing, only spelled different. Is this English class or what???
  • New.Canadian.DB.Owner and propane1 have said thanks
#9 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted July 13, 2015 - 05:57 PM
Not sure, but the carb is clean externally.  I would think that if the atmospheric vent was plugged, there would not be any air getting into the carb as the fuel left to be pushed up the fuel line when the float rose.
#10 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
I removed the fuel line & blew air back through the shutoff.  No change.
The fuel line has a downward slope over the entire length.  Not sure which inlet you mean, but I twisted the carb inlet a couple of degrees to get it sitting flat or slightly downhill as the fuel runs.  I can't figure out how to get the shut off valve out of the rubber fitting at the tank.
Fuel filter is just one of that has a screen mesh in the centre.  I don't think it has a right or wrong way.  I did try a paper filter style filter, installed correctly, but it did the same thing.
Google it.
  • DougT, MH81, hamman and 1 other said thanks
#11 TimW OFFLINE
TimW
  • 414 Thanks
  • 271 posts
Posted July 13, 2015 - 06:21 PM
This might or might not be relevant, but I have dealt with 2 of the small generators with the Tecumseh, 8hp I think. of that style.  Both would just die after running for a few minutes.  I went thru the carbs several times.  I blamed vapor lock, I blamed the low oil shutdown.  I could not isolate anything.  I even ran a remote gravity fed fuel tank, made no difference.  Looking back on it, I wander if it could have an erratic valve problem, maybe sticking open.  If it turns out to not be vapor locking, please let me know what you found.
#12 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,974 Thanks
  • 9,616 posts
Posted July 13, 2015 - 06:26 PM
Vapour is what they get in Ontario. In the rest of Canada and other English speaking countries, we get vapor.
#13 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,112 Thanks
  • 4,883 posts
Posted July 13, 2015 - 06:28 PM
Yeah,  its kinda like turning the soil with a plough.    :thumbs:
  • New.Canadian.DB.Owner and LilysDad have said thanks
#14 propane1 OFFLINE
propane1
  • 8,458 Thanks
  • 4,034 posts
Posted July 13, 2015 - 06:35 PM
With the float bowl vent blocked, and the fuel fowling into the bowl, it would have to get air from some where to allow gas to run into the bowl ?? Just another thought and guess. Noel
#15 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted July 13, 2015 - 06:57 PM
This is on the MTD site about vapor lock
http://support.mtdpr...engine-stalling
  • MH81, Alc, New.Canadian.DB.Owner and 1 other said thanks
