I got this ford yt16 with some mods to it, anyways it started as a stock yt16 with no engine seat or trans so pretty stripped apart, well we seen these people around were i live have jacked up lawn mowers so that idea came to mind that we should build one. on a weekend we were bored we built up a frame and front axel and for a transmission it has a peerless 820 6 speed im pretty sure it started out with 31's but them tires were junk so we found 33's super swamper tsl used them till side walls blew with the 33's the snapped the lawn mower axel right inside the diff so we turned down some old ford f150 axels to put in it to be more stronger after that we got a set of 35's justt some bfg all terrains we put a vanguard 16hp vtwin in it the motors not stock but sounds good. ill try to get some pics on it later.
my homeade lawn mower
#2
ONLINE
Posted July 13, 2015 - 11:02 AM
Welcome! You'll fit right in here. All the young ones will follow you around begging for your autograph. The old ones will want a ride your tractor.
- boyscout862 said thank you
#3
OFFLINE
Posted July 13, 2015 - 02:59 PM
thats what it seemed at the show I just went to its definitely a attention getter
#4
OFFLINE
Posted July 14, 2015 - 10:34 PM
here it is next to a stock yt16
found out theis 37s were to big
so we had ford f150 made to fit the trans
and talk about time going by this was the first time we had it out of the shop with a mock up motor in it and some junk tires on it
- Alc and stiemmy have said thanks
#5
ONLINE
Posted July 15, 2015 - 07:40 AM
Now I know where I have seen that before..are you wizard from XMM?
#6
OFFLINE
Posted July 15, 2015 - 10:58 AM
nope im not i just know pretty much everything about it tho.
#7
ONLINE
Posted July 15, 2015 - 11:09 AM
Is there anything going on over there, or is it just Kel's own personal site for selfinduced back patting? Atltf went down the crapper too, just a bunch of wanna bees kissing FF's rearend
#8
OFFLINE
Posted July 15, 2015 - 08:50 PM
i really dont no i havent really talked to him before i dont have anything to do with that site i started this one to get more info on my sears's and to show how the bigford was built i got all the info to build another one if i want to
