Make sure you tell my wife that some of my ideas work! She thinks everything I say is doomed to fail.
Ratchet Strap Question
#31
ONLINE
Posted July 14, 2015 - 02:22 PM
- larrybl and grnspot110 have said thanks
#32
OFFLINE
Posted July 14, 2015 - 02:51 PM
Let me see what I can come up with to try and demonstrate how I do my straps. No need for velcro, knots, clamps or anything else. Biggest thing though is it has to be strap handles that have room to feed the wrapping you make back through it. I will get dad to snap some pics as I am doing one to show how I do it and the end result.
- larrybl, MH81, Alc and 1 other said thanks
#33
OFFLINE
Posted July 14, 2015 - 03:11 PM
I always tie them back on to whatever I am hauling. I have had a few ratcheting mechanisms give out on trips before and was glad I tied the ends back to the tractor or motorcycle, that way even if something fails it usually still holds the load down enough for me to catch it and restrap.
- MH81, Alc and WNYTractorTinkerer have said thanks
#34
OFFLINE
Posted July 14, 2015 - 07:48 PM
Edited by toppop52, July 14, 2015 - 07:50 PM.
- MH81 said thank you
#35
ONLINE
Posted July 16, 2015 - 07:04 PM
When I worked at the lumber yard I did the tape method from time to time. Mostly though I would A) Roll the tail and tuck it under the strap and tighten it between the load and the strap or B) Roll it so it could be tucked tightly between the rub rail and the bed. Never lost one or had them come loose in 7 years of multiple loads per day.
For my personal stuff I use the tape method mostly. I got away from Duct tape a few years ago though. It's too darn sticky and annoying to get off the strap. Instead I now use electrical tape. A few wraps around and it holds just as well and it's easier to peel off and cheaper as well.
- MH81 and KennyP have said thanks
#36
ONLINE
Posted July 16, 2015 - 07:27 PM
The left over Velcro I had worked great. I have to stop at Ace Hardware tomorrow to see if I can find some heat resistant material, black hi-temp paint, and see if they have the two sided Velcro straps that can double to hold the straps together when stored.
Thanks for all the tips!
#37
ONLINE
Posted July 17, 2015 - 06:17 AM
I mostly use your A method on my loads!
#38
ONLINE
Posted July 17, 2015 - 06:38 AM
For shorter ends, I bring the end back into the ratchet.
Longer ones I roll up & secure as shown with the tape, clamp, etc, only I use a "ball bungee" around them.
- KennyP said thank you
#39
OFFLINE
Posted August 11, 2015 - 08:08 PM
We took a short video when we loaded some tractors this past weekend to help explain what I do with the loose ends. I will try and get it uploaded here in the next couple of days. Might be a little hectic though with the Dover show this coming weekend.
#40
OFFLINE
Posted August 11, 2015 - 10:43 PM
My method of choice as well.
