Eaton/Peerless?
6 replies to this topic
#1 KennyP ONLINE
  • 37,442 Thanks
  • 45,469 posts
Posted July 12, 2015 - 01:45 PM
I know shortly after getting this rear end, I asked about it. But it's been a while and I have dug it out again. The #'s are:
MOD2548
Peerless
4040 4226
It is offset to the right about 1-1/2" from what I see. The LH axle tube is right at 3" longer than the RH. I sure would like to know what it came from. It is not a Ford/Jacobsen. Nor a Sears FF. 5 Bolt hubs that are different from any I have seen. I am wondering which other brands used the Eaton/Peerless combo. Any folks out there with an idea, speak up!
There is no brake on this at all! Also, the FWD/REV lever has what appears to have been a detent for Neutral on the LH side of the frame. A real odd ball as far as I am concerned.
I have a yet to be named project coming up and had hoped to use this. But, I'll be using a spare Ford set-up instead. I'm fixing to stuff one of these where it has never been before!
  • Alc, boyscout862 and Chopperhed have said thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,779 Thanks
  • 9,918 posts
Posted July 12, 2015 - 02:47 PM
Jacobsen used Eaton/Peerless combos in their front mount, rear steer units.
  • KennyP and Chopperhed have said thanks
#3 glgrumpy ONLINE
  • 8,553 Thanks
  • 7,878 posts
Posted July 12, 2015 - 03:55 PM
My Speedex has that. Not sure I have good pix of it to see much, I'll look. Mine was red tho, same as tractor. MTD and some allis? I think used.
Edited by glgrumpy, July 12, 2015 - 04:01 PM.
  • KennyP, Chopperhed and TomLGT195 have said thanks
#4 KennyP ONLINE
  • 37,442 Thanks
  • 45,469 posts
Posted July 12, 2015 - 04:04 PM
But the mount is different! Mine still has the frame mounts on it!
  • Chopperhed said thank you
#5 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted July 12, 2015 - 07:21 PM
Kenny that unit is from a gilson made ford , I have one sitting in my shed. That one has a newer and smoother hydro unit, great replacement unit for your Ford if Its acting up. The brake unit for that unit is a disk set up. They were easy to use on other units with minor adaption, so that may be why its missing.
  • MH81, Alc and KennyP have said thanks
#6 HALFSCALE OFFLINE
HALFSCALE
  • 484 Thanks
  • 521 posts
Posted July 13, 2015 - 02:11 AM
Steiner also used a similar set up, both front and back.
#7 KennyP ONLINE
  • 37,442 Thanks
  • 45,469 posts
Posted July 13, 2015 - 04:42 AM
Thanks guys! I saw the shaft for a brake. It was hidden by a hose.
