Larger? pully for a 46" deck
3 replies to this topic
#1 abrasv OFFLINE
abrasv
  • 18 Thanks
  • 36 posts
Posted July 11, 2015 - 07:21 PM
I have a 46" deck on my 318 and I would like to upgrade the size of the pulley to make the blades spin faster. Not sure this can even be done but I seem to remember someone else doing this very thing.
Can anyone tell me what would be needed to do this if it is possible?
Thanks,
Jim
#2 Alc ONLINE
  • 7,244 Thanks
  • 7,588 posts
Posted July 12, 2015 - 06:10 AM
Jim wouldn't you need to go with a smaller deck pulley to spin it faster ? I have a 318 w/50"deck and I always thought it didn't have the blade speed that others have . There was a thread about this subject
  • abrasv said thank you
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted July 12, 2015 - 06:29 AM
Here is the JD part # for the speed up pulley for the 50 deck:
AM116141 SHEAVE 1 (OPTIONAL) (INCREASES BLADE TIP SPEED APPROX. 10 PERCENT FOR IMPROVED CUTTING QUALITY)
I read that others bought it to use on a 46 deck, but no follow-up reports. So I don't know if that actually works.
Dimensions of the speed up pulley:
 OD 6.610"
 Bore .752"
 Groove size .688".
If I remember right, the stock size pulley is 7".
  • Alc and abrasv have said thanks
#4 abrasv OFFLINE
abrasv
  • 18 Thanks
  • 36 posts
Posted July 12, 2015 - 04:49 PM
I do believe you are right! I'm going to check in to the part# that CAT385B gave.
CAT385B: thanks for that info. It may be a week or so but I'll look into it and leave a follow-up as to if it works.
