Mounted up the cultivator bar onto the front lift (same lift as was used for the middle buster ) I tried to use the complete set-up without moving the front axle wider so it will still fit my 5x10 trailer the bar should clear the side rails . It has gauge wheels half sweeps with dirt shields . There is also a single shank sweep mounted on a separate lift on the rear to get the spot where the rear tire tracks .I'll get a picture and post that later . Everything went on well until I tried mounting the shanks in between the lifting arms . The manual explains and has a general picture but when I tried the shanks hit a cross-member on the lift frame , but by just a little , if it was moved a 1/4" it wouldn't have hit at all. I ended up making tapered shims to cock the shank enough so it wouldn't hit the cross-member . I don't really have a garden with row crops that you would use it on but I tried going in a spot next to where the sweet potatoes are .I was too wet but I couldn't wait lol
