Electric clutch repairable?
6 replies to this topic
#1 TAHOE ONLINE
TAHOE
  • 8,337 Thanks
  • 5,818 posts
Posted July 10, 2015 - 11:32 AM
I'm wondering if there is something I can put back over the windings on this clutch?
I guess first I should ask if I can test to make sure it still works? PO had it switch disconnected but he said it was switch issue. Anyway, I thought maybe the liquid electrical tape?
I thought I read on here recently someone said on another thread pour some hot tar over one....?
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,670 Thanks
  • 4,645 posts
Posted July 10, 2015 - 11:47 AM
I used JB Weld to repair one of mine..... Start at post 944 here http://www.mytractor...ney-pit-63.html
  • TAHOE said thank you
#3 olcowhand ONLINE
  • 43,149 Thanks
  • 32,006 posts
Posted July 10, 2015 - 11:56 AM
I use either epoxy or fiberglass resin. I don't advise JB Weld as it contains tiny metal flecks that may cause problems electrically.
#4 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,670 Thanks
  • 4,645 posts
Posted July 10, 2015 - 12:22 PM
I checked JB with an ohm meter set to the lowest ohm setting, where you can get a reading just by touching the leads. and couldn't find any resistance in JB tith the probes almost touching each other. epoxy or fiberglass resin would be fine too.
  • olcowhand and TAHOE have said thanks
#5 olcowhand ONLINE
  • 43,149 Thanks
  • 32,006 posts
Posted July 10, 2015 - 12:42 PM
The only reason I mentioned JB as a possible problem is because when using it to reglue starter magnets back in, it drew the glue to the magnets. But I never tested after curing.
#6 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted July 10, 2015 - 01:44 PM
Black RTV is what I used.
#7 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,670 Thanks
  • 4,645 posts
Posted July 10, 2015 - 01:56 PM
Ahhhh, JB may be magnetic.... I never tested that, but I will :wave:  and report the result. Thanks
