unknown Shaw walk behind garden tractor
8 replies to this topic
#1 orchard man 1romeo4010 OFFLINE
  • 5 Thanks
  • 2 posts
Posted July 09, 2015 - 09:38 PM
can anyone ID this photo?
  • Traill95 and Tbrooks have said thanks
#2 DougT OFFLINE
DougT
    Dog Approved
  • 8369 Thanks
  • 5751 posts
Posted July 09, 2015 - 11:14 PM
Welcome to the forum. I see some parts of a Shaw in there. Looks like its been highly modifed. Can you get some closer pictures at different angles? Is the gearbox cast iron or aluminum?
  • MH81 and orchard man 1romeo4010 have said thanks
#3 Alc OFFLINE
  • 9079 Thanks
  • 8320 posts
Posted July 10, 2015 - 05:18 AM
Welcome to GTTalk !
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted July 10, 2015 - 06:22 AM
:welcometogttalk:    I'd call it "THE BEAST"
  • orchard man 1romeo4010 said thank you
#5 boyscout862 OFFLINE
  • 15176 Thanks
  • 9995 posts
Posted July 10, 2015 - 07:51 AM
Welcome to GTT.
#6 jd.rasentrac OFFLINE
jd.rasentrac
  • 4979 Thanks
  • 4413 posts
Posted July 10, 2015 - 11:41 AM
welcome to gtt, can't say anything to the walk behind - but, is it a Deere on the right side?
#7 Clifford Bridgford OFFLINE
Clifford Bridgford
  • 558 Thanks
  • 200 posts
Posted July 10, 2015 - 08:44 PM
That is a model H3 which came out around 1940 and was discontinued during the war.  It used a 3 HP Model B Briggs.  It was designed to have 24" plant clearance when cultivating.  It had one speed forward which could be varied with a manually adjusted sheave on the engine.  It had no reverse, but had a unique power turn system where you pulled back on either the right or left control handle and you lifted the driven bull gear out of mesh with the drive gear.  This is the only Shaw that used an angle iron frame. Design is very similar to a Peppy Pal and uses a Peppy Pal design cutter bar, but rear attachments are the same as the D-series.  The engine
pivots to loosen or tighten the drive belt for the clutch and the tractor uses 5.50 X 16 tires.  I have two in my unrestored project shed.
Cliff
  • DougT, MH81 and orchard man 1romeo4010 have said thanks
#8 orchard man 1romeo4010 OFFLINE
  • 5 Thanks
  • 2 posts
Posted July 10, 2015 - 08:56 PM
Here are some more views of the Shaw Walk Behind ....I do not believe,that it has been modified   the gearbox is cast iron                  I would like to know what model this is & if it might be rare. What would it be worth for parts? Thank you!
  • DougT, boyscout862 and Tbrooks have said thanks
#9 Tbrooks OFFLINE
Tbrooks
  • 523 Thanks
  • 330 posts
Posted July 15, 2015 - 09:13 PM
That looks like a transitional model, some where between the d series and the H5. I wouldn't mind having one like that in my barn!
