squeel from under side cover. B110
8 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 09, 2015 - 10:05 AM
fired up the B110 and it was making a squeeling rubbing sound . unhooked the drive belt , no change . unhooked the starter belt , no change . sprayed liquid wrench at the bgb end of the drive shaft , maybe a change ?? sprayed some between the flywheel and starter pulley , little more change ?? sprayed a little more and it finally went away . its making me nervous . any thoughts ?
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted July 09, 2015 - 10:21 AM
Anything hitting or rubbing on the driveshaft?
  • alec said thank you
#3 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 09, 2015 - 10:45 AM
nope ,it appears to be clear
#4 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,322 Thanks
  • 9,788 posts
Posted July 09, 2015 - 11:35 AM
Baby rabbit?
#5 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 09, 2015 - 12:05 PM
Baby rabbit?
that was the first thing I checked for .... :D
#6 MH81 OFFLINE
Posted July 09, 2015 - 12:08 PM
Oil in the BGB?
#7 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 09, 2015 - 12:13 PM
Oil in the BGB?
yep .full up to the top of the fill elbow
#8 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted July 09, 2015 - 02:07 PM
I've seen the arm on the rockshaft (where your rear lift would pin up to it) can get close enough to the driveshaft, so that the arm or pin through it, can rub the driveshaft occasionally.  I have that issue right now with my HB-112.  Started hearing a low whine, and when I peeked, sure enough, I had a shiney strip on my driveshaft.  It's rubbing only when the lift is all the way forward.  A shim/bushing/washer on the opposite side keep the pin to my rear lift rod from rubbing.
hope that makes sense...
#9 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted July 09, 2015 - 02:54 PM
you may be on to something . when I fired it up and pulled my lever back it did squeel a little bit . it has spray all over it right now so that is deadening it a bit . I am going to pull the side plate on that side this time and check it out .
