10XL gear shift question
7 replies to this topic
#1 Nebraska Cowman OFFLINE
Nebraska Cowman
  • 16 Thanks
  • 9 posts
Posted July 08, 2015 - 05:54 AM
It seems like when I start the engine with the shifter in neutral then when I go to put the shifter in gear the transmission gears seem to keep moving with the clutch pedal depressed making it grind to go into gear. Is there or should there be a brake to stop the transmission from turning while shifting? The clutch otherwise seems to work fine, fully releasing to stop and to shift from gear to gear, just not from neutral to gear.
  • hamman said thank you
#2 boyscout862 ONLINE
  • 12,839 Thanks
  • 9,162 posts
Posted July 08, 2015 - 06:31 AM
The clutch belt probably needs to be adjusted. The belt guides and the mechanism that stops the belt should be adjusted too. If it has sat for awhile the pulleys maybe rusted and catching on the belt. Check the manual for the correct proceedure. Good Luck, Rick
  • hamman and Nebraska Cowman have said thanks
#3 Nebraska Cowman OFFLINE
Nebraska Cowman
  • 16 Thanks
  • 9 posts
Posted July 08, 2015 - 06:51 AM
OK thanks, I'll check it out this weekend. I think it is going to be to hot to work anyway.
#4 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted July 08, 2015 - 06:53 AM
Not sure how these older ones are set up, but Rick's answer sounds about right. Have you read the adjustment procedure in this manual? Also, the next page is the brake adjustment. Seems there is a tab on the one pulley that should deflect the belt and stop it from turning.
  • hamman, boyscout862, 6mikey7 and 1 other said thanks
#5 TAHOE OFFLINE
TAHOE
  • 7,972 Thanks
  • 5,673 posts
Posted July 08, 2015 - 07:13 AM
I had a similar issue on my Suburban, I was always grinding gears. The clutch adjustment on the custom I think is very similar to the suburbans since they use the same rear axle. Mine was a combination of a worn belt and no lining on the brake band, the brake does help stop the transaxle's inyards turning somewhat, but it's more belt disengagement.
Read through this link, it may help you get an understanding of the setup, yours should be very similar. I am betting your drive belt is old and worn and grabbing pulleys even with clutch pushed in.
http://gardentractor...e-and-belt-r183
  • hamman, KennyP and Nebraska Cowman have said thanks
#6 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted July 08, 2015 - 08:05 AM
Our custom 10XL does that also. I usually just leave the clutch in a little longer before I shift.        Roger
  • Nebraska Cowman said thank you
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted July 08, 2015 - 03:14 PM
Patience when shifting may pay dividends.
#8 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted July 14, 2015 - 05:01 PM
I agree, adjusting drive belt is probably the issue. I just replaced a belt on my 10XL that was doing the same thing. Issue went away with new belt and a small adjustment.
