Problem - Old JD 265
9 replies to this topic
#1 gb856 OFFLINE
gb856
  • 4 posts
Posted July 07, 2015 - 08:50 PM
My 1991 John Deere 265 spits and cuts out while I'm mowing on inclines or hills. I don't have the problems when the mower is turned off, so I'm confused what could be the problem. Could it be a safety switch on the mower? Any help would be appreciated!
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,797 Thanks
  • 4,291 posts
Posted July 08, 2015 - 02:40 AM
Welcome to gtt. Can be a fuel problem - dirty tank, dirty tube, dirty filtre aso. This are the first things you've to check - and then, we'll see what happens.
  • Trav1s and gb856 have said thanks
#3 oldedeeres ONLINE
oldedeeres
  • 10,280 Thanks
  • 5,019 posts
Posted July 08, 2015 - 08:35 AM
Welcome aboard, gb856! Lots of Deere guys here to give you a hand with this. Could be some sludge in the tank that sloshes around when you're on an incline. Does it do it when the tank is full as opposed to almost empty?
  • gb856 said thank you
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted July 08, 2015 - 08:41 AM
:welcometogttalk:
#5 Trav1s OFFLINE
Trav1s
  • 3,512 Thanks
  • 4,493 posts
Posted July 08, 2015 - 01:08 PM
Junk in tank, plugged tank pickup, dirty fuel filter (if there is filter), or float out of adjustment to name a few.
#6 gb856 OFFLINE
gb856
  • 4 posts
Posted July 08, 2015 - 07:37 PM
But it only does it when the mower is running, tried without no problem??
#7 gb856 OFFLINE
gb856
  • 4 posts
Posted July 08, 2015 - 07:38 PM
Thanks! Why does it only happen when the mower is running??
#8 gb856 OFFLINE
gb856
  • 4 posts
Posted July 08, 2015 - 07:41 PM
Yes, even with a full tank. But it doesn't happen when mower is not engaged?
#9 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,797 Thanks
  • 4,291 posts
Posted July 08, 2015 - 09:04 PM
it can be dependent about load. when the engine is idling, you only have a low load.
but it isn't easy, to find a solution w/out seeing and hearing the tractor working. it's like a doctor diagnosing a disease on telephone.
#10 oldedeeres ONLINE
oldedeeres
  • 10,280 Thanks
  • 5,019 posts
Posted July 09, 2015 - 04:57 PM
Just guessing, but maybe a pin hole in the fuel line, sucks air when under a load but idling doesn't stress the feed.
