Sleeve hitch for an Original
2 replies to this topic
#1 Tennblue59 OFFLINE
Tennblue59
  • 451 Thanks
  • 522 posts
Posted July 07, 2015 - 07:15 AM
Starting to collect pieces for my 62 Cub Original build. Question about sleeve hitches.....
Will the sleeve hitch from a narrow frame model work on an Original frame?
If not, can it be reasonably adapted - For example, the casting is the same, but you would need to modify the bracket that mounts it.....
what parts would have to be modified?
While I have seen a couple Original hitch sets, seems like the Narrow frame ones are much more common....
Thanks in advance!
#2 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted July 07, 2015 - 09:16 AM
The Original rear sleeve lift is unique to that model . Its casting and bar that goes between the lift handle and casting are different as is the lift spring assist  .
The narrow frames that were made after the Original used a similar but different cast part and bar and aren't interchangeable and I don't think you could modify the cast part to work . Also the narrow frame bar is shorter than the one on a Original and is straight while the Original bar has a bend ..
First picture is a Original  , second picture is a 70 or 100
I have seen reproductions of Original rear  lifts on ebay and know someone is making them .
Edited by Jlaws, July 07, 2015 - 09:19 AM.
  • KennyP and Tennblue59 have said thanks
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted July 07, 2015 - 11:33 PM
There is an original sleeve hitch on eBay for about $205 with free shipping. Search "cub cadet hitch"
Edited by wvbuzzmaster, July 07, 2015 - 11:34 PM.
  • Tennblue59 said thank you
