Interesting tid bit about IH
10 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted July 05, 2015 - 10:08 PM
So I have been getting nervous about all my IH tractors and garden tractors having regular keys. So today I did an inventory of keys and this is what I found. The CC 102 uses an indak that will not release itself from the ignition switch, so it is safe lol. The CC 109 parts tractor has no key in the ignition, but the CC 108 key fits and operates the ignition on the 109, score but not surprised. It was when I went over to the Farmall 140 which has just an On/Off key switch and read the numbers on the key in its ignition and the one from the CC 108 I found... They are keyed the same!! Who would have thunk that. So I ask this question, are all IH tractors keyed alike, or is this just a coincidence?
  • tinbender7 and Coventry Plumber have said thanks
#2 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted July 05, 2015 - 11:32 PM
Well I know my International cub tractor uses the same key as my Originals , 100 , 122 , 123 etc .   In fact all the early IH
Cub Cadets used the same cut key ...
  • wvbuzzmaster and tinbender7 have said thanks
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted July 05, 2015 - 11:47 PM
So you suspect the indak switch on my CC 102 is wrong?
#4 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted July 05, 2015 - 11:51 PM
Yep , its definitely been replaced .
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted July 06, 2015 - 12:01 AM
Well, sounds like I will need to get that 109 parts switch installed some day (after I have a key made for it).
#6 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,112 posts
Posted July 06, 2015 - 01:26 AM
Alot of full sized tractors and machinery are like that to.Especially the newer JD 4x4 tractors.Couple of them got stolen up the road the other day.
#7 MH81 OFFLINE
Posted July 06, 2015 - 06:23 AM
There are pros and cons to having common keys.
I also worry some at shows, but not to much if there is some kind of security or camping membership.
#8 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted July 06, 2015 - 10:46 AM
Which is why you disconnect things. Backfires dont it? Lol
#9 MH81 OFFLINE
Posted July 06, 2015 - 12:32 PM
I didnt have time to install Casey Spark Plug Grounds on all of them...
#10 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted July 06, 2015 - 01:50 PM
You did Kaylen proof them all though lol.
#11 IHCubGuy ONLINE
IHCubGuy
  • 1,520 Thanks
  • 1,596 posts
Posted July 07, 2015 - 07:40 PM
In the 60's and 70's that key was used in pretty much all the tractors IH built.  We had a 656 that had that key, our 766 uses that key, so on and so on.  It was WIDELY used to say the least.  One thing to watch it the actual keyed end of the key.  I have IH keys in 4 different styles of handle ends all with the same switch end.
  • wvbuzzmaster said thank you
