I'm working on trying to fix a Farmall Cub that froze last winter.
http://gardentractor...e-5#entry479966
The coolant that I put in it wasn't good enough, the top of the head is cracked and the front bolster is cracked (part that the rad, steering box and front axle mount to).
I can't see any other cracks or spots where water/coolant is leaking out.
The engine runs good, the oil looks good, the level is at the full mark, doesn't appear to be rising. ???
Question Where do these tractors crack when they freeze? Where should I be looking?
