Air Compressor
6 replies to this topic
#1 KC9KAS OFFLINE
KC9KAS
  • 4,960 Thanks
  • 4,394 posts
Posted July 04, 2015 - 12:39 PM
Some time ago, my wife bought me a Harbor Freight Media Blaster. I told her my little 8 gallon compressor wouldn't last 1 minute with the blaster, so we have been keeping an eye out for a new compressor.
She has a Home Depot store credit card and it was offering some promotionals, so we took advantage of it.
Now, my blaster says it needs 10 CFM@ 90 PSI to operate, so here were my options:
#1  60 gallon, 155 PSI, and 11.5 CFM @ 90 PSI  $489.00
http://www.homedepot...C602H/205389936
OR
#2  80 gallon, 155 PSI and 14 CFM @ 90 PSI $849.
http://www.homedepot...C801H/203187346
So what would you do???
Edited by KC9KAS, July 04, 2015 - 12:44 PM.
  • hamman said thank you
#2 olcowhand ONLINE
  • 36,471 Thanks
  • 30,059 posts
Posted July 04, 2015 - 01:31 PM
If you can afford, go for the largest one you can.  The numbers those blaster manufacturers put out are way off.  You need all the air you can get and then some.
  • Alc, hamman and freedhardwoods have said thanks
#3 olcowhand ONLINE
  • 36,471 Thanks
  • 30,059 posts
Posted July 04, 2015 - 01:35 PM
I don't see any duty rating on the largest one even, so see if it is rated continuous duty.  VERY important when blasting as you usually keep it humming for long times.
  • Alc and hamman have said thanks
#4 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 5,782 Thanks
  • 2,641 posts
Posted July 04, 2015 - 02:19 PM
I would go for the larger one. It is just short of whay you would need to run a DA sander for a long time but will do well for the media blaster. Good luck.
Roger
#5 Jazz ONLINE
Jazz
  • 1,638 Thanks
  • 1,058 posts
Posted July 04, 2015 - 06:08 PM
Get the bigger one,  the smaller unit would not keep up and its annoying having to constantly stop sandblasting waiting for a compressor to catch up. ...I have a RK 5hp compressor 18CFM @90 and it gets time to rest when when I'm using my HF pot blaster.
#6 Clifford Bridgford OFFLINE
Clifford Bridgford
  • 356 Thanks
  • 96 posts
Posted July 08, 2015 - 09:57 PM
CFM Required for Nozzle Size
Cliff
  • olcowhand said thank you
#7 rust addict OFFLINE
rust addict
  • 242 Thanks
  • 174 posts
Posted July 12, 2015 - 02:18 AM
Craigslist.
