Grease fittings for 917.255919 mower deck
7 replies to this topic
#1 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted July 04, 2015 - 12:01 PM
Anyone know if this has grease fittings for the spindles?
I've looked everywhere for a detailed drawing of the spindles, in case my eyes have failed me.
Can't find anything.
Surely they didn't make "life time" lubed bearings.
Thanks for considerations.
After the fact: Removed the deck cover and no zerks anywhere.  Oddest thing ever seen for a high speed spinning shaft.
Edited by Phluphy, July 04, 2015 - 02:19 PM.
#2 KennyP ONLINE
  • 37,451 Thanks
  • 45,472 posts
Posted July 04, 2015 - 02:44 PM
Usually the zerks were below deck!
  • Phluphy said thank you
#3 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 04, 2015 - 03:28 PM
grease zerks ??? how would they sell you parts if you greased it and made it last
#4 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted July 04, 2015 - 04:44 PM
Nope, it has sealed bearings in the mandrills. Grease zerks are on the bottom of the steering shaft (under the tractor), Inside the front rims, and on the steering spindles.
  • Alc, KennyP and Phluphy have said thanks
#5 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted July 04, 2015 - 09:29 PM
Yes, first place I looked, under the deck per usual.  Nada.
This is my first experience with no zerks on deck spindles.  Always learning.
Thanks for the responses.
  • larrybl said thank you
#6 Jazz OFFLINE
Jazz
  • 2,302 Thanks
  • 1,403 posts
Posted July 15, 2015 - 03:11 PM
After reading this thread i thought I better take a look at my mower decks parts list as I thought it odd I did not see any grease fittings above deck.. 1 grease zerk on each spindle!  Good thing this was my first season with tractor. They each took grease easily so PO kept up her maintenance. They seem to take lots of grease so I gave each a dozen or so pumps.. I was expecting to see some grease ooze out but none did..Did I put enough grease in? I also scraped underside of deck while I was there and sprayed underside with Rust Check oil...i spray that $!!# on everything...
SO,,,CAN AM I OVER GREASING?
thanks
mower deck is # 917 253250 mounted on the MIGHTY SS16
Edited by Jazz, July 15, 2015 - 03:19 PM.
#7 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted July 15, 2015 - 03:21 PM
You should have a zerk on the inside of the front rims, I grease mine till I see it at the inside hub, but be careful not to push the black plastic hub dust cover off the outside of the rim.
Also there is one on the front of the spindle arm where it attaches to the axle, and "should" be one on the steering pivot, but I have seen older pivets without.
  • Jazz said thank you
#8 Jazz OFFLINE
Jazz
  • 2,302 Thanks
  • 1,403 posts
Posted July 15, 2015 - 03:27 PM
Thanks,,I found all the other grease fittings on tractor when I brought it home last season.. Tractor came with original owners manual for tractor and snow blower attachment but only a parts list for mower attachment which I had only glazed over...Really had to look at parts list to find the "E" representing the grease zerks.
