66 chief 1000 starter/gen oiling?
5 replies to this topic
#1 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted July 04, 2015 - 08:21 AM
Hi guys
Does the starter/gen on a 1966 chief 1000 need periodic oiling?  I just read the Delco/remy  piece that mentioned periodic  oiling.. Thanks much!
Mike
Genoa,IL
Edited by Mike125s, July 04, 2015 - 08:21 AM.
#2 Bolens 1000 ONLINE
  • 15,403 Thanks
  • 18,277 posts
Posted July 04, 2015 - 08:40 AM
Do you have the Dual bearing or bearing and Bushing combo?
The ones with the bushing in the rear should have an oil cap and a few drops from time to dime will do.
  • Alc and Mike125s have said thanks
#3 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted July 04, 2015 - 02:38 PM
I think its the long one...Not sure?? I don't see an oil fill cap anywhere??
Thanks!
Mike
Genoa,IL
Edited by Mike125s, July 04, 2015 - 02:47 PM.
#4 glgrumpy OFFLINE
  • 8,803 Thanks
  • 8,009 posts
Posted July 04, 2015 - 10:43 PM
No caps, no oiling!  I just got that old Massey and starter is froze up. Tore apart and has bearings with some grease dried in them, and a knock-out cap one end. Maybe that is way to lube?  Bet not meant to be lubed, cept in tear-down or repair mode. NOW, can't get the bearing with end cap to slip off the armature. don't see any snap ring or nothing. Have it soaking now to see if comes off.
  • Mike125s said thank you
#5 Mike125s OFFLINE
Mike125s
  • 57 Thanks
  • 121 posts
Posted July 10, 2015 - 06:26 AM
Thanks!
Mike
Genoa,IL
I think this is the dual ball bearing generator
#6 Bolens 1000 ONLINE
  • 15,403 Thanks
  • 18,277 posts
Posted July 10, 2015 - 06:47 AM
Thats the dual bearing one you have there, no oiling necessary
