Posted July 03, 2015 - 07:02 PM
Posted July 03, 2015 - 07:20 PM
Posted July 03, 2015 - 07:23 PM
That's an impressive exhaust system on it. Looks like a nice project
Edited by Motofan81, July 03, 2015 - 07:24 PM.
Posted July 03, 2015 - 07:38 PM
Looks like Grumpy left one get away from him.
Maybe he's getting out of the hobby?
Posted July 03, 2015 - 11:08 PM
Well, that sure IS junk, best to let ME come and get it out of your place and be prettier then! Is that a 1630? or maybe late S-23 you think or know? Should say on that circular hood decal, can't read in pix. Has a sideways T-92 3spd then? Those being stuck in gear is common. You can pull the top off with just those four bolts and move the gears back to N and forks and lever too and then put back on. Should work for at least awhile. Make the shifts with long deliberate H pattern, not a quick slam and jamb on these. If you go to the Power King forum here,, there is a posting at top about repairing the ball end on the shift lever. You or someone welds it up to build back size, then have to grind down sides of it to proper dimensions to fit between the shift rails inside trans. This end wears down and then jambes between the rails when it is worn enough and jambs there. This is same trans as PK's used.
Looks about like any old Speedex with the rust and things welded on and attacked. These are easy to tear down and fix/paint needed items. Many times a good blasting or cleaning of the parts and all the turning points and some grease will make them work much better Engine is Briggs and may need carb build or mag cleaning of rust or replacement. Look for mouse nests under the main cover if setting long time. You'll like this rig, there are a few parts guys out there, but little harder to find. Most are in Ohio or PA area, where these were made. Scroll thru t he posts here and get some tips and places to ask.
Posted July 04, 2015 - 05:12 AM
Posted July 04, 2015 - 07:06 AM
Posted July 04, 2015 - 11:27 AM
Nice tractor, I would bring it home. Muffler does not look original likely why the added plumbing. Eyecatching as it is that would be the first thing I'd paint.
Edited by Jazz, July 04, 2015 - 11:29 AM.
Posted July 04, 2015 - 11:41 AM
From the start of your post it sounds like you bring junk home , but it looks like it has possibilities.
Posted July 06, 2015 - 10:31 PM
Edited by Motofan81, July 06, 2015 - 10:33 PM.
Posted July 07, 2015 - 03:27 AM
10 hp is series 24 I believe. Many times I don't find the numbers, then when sanding or blasting find them stamped into air housing either at top or on side down low or near starter say, if one. You sure not a 16horse? They used them alot on Speedex, but maybe that is newer models? Those are series 32 and have variations. One parts book for Series usually has the diff variations and systems listed for that series, so covers many years and models. Here maybe in manusls or Briggs site has way to print them off it.
Posted July 07, 2015 - 08:05 AM
Posted July 07, 2015 - 08:37 AM
If I'm not mistaken there should be an ID plate riveted to the shroud that wraps around the cooling fins on the crankshaft side
Parts are readily available for the most part
Posted July 07, 2015 - 09:07 AM
There are a couple of holes there that a plate could have been attached to but only on one side.If I'm not mistaken there should be an ID plate riveted to the shroud that wraps around the cooling fins on the crankshaft side
Edited by Motofan81, July 07, 2015 - 09:11 AM.
Posted July 07, 2015 - 02:39 PM
Edited by glgrumpy, July 07, 2015 - 02:41 PM.
