a helpful painting tip
6 replies to this topic
#1 alec OFFLINE
  • 382 Thanks
  • 412 posts
Posted July 02, 2015 - 09:07 PM
I painted cars for twenty + years so I thought I would share a tip .
tin foil works very well for masking dirty parts ( engine parts , hoses , greasy shafts ) or parts you are scared to tape on ( stuff the tape may peel off )
the coolest thing is that you can wrap it and squish it and it stays .
if you get it tight enough and strait enough you can get a pretty clean line .
works great for wiring harnesses and chains .
you can put a clean rag under it if you are painting something you are worried about scratching
heavy duty foil is the best but any will work ( it just likes to tear easy )
be careful using a bunch of small pieces . you want enough on each end to squish together , it doesnt hurt to throw a piece of tape at it eather
hope this is helpful to someone
  • olcowhand, larrybl, Gtractor and 20 others have said thanks
#2 Chopperhed OFFLINE
  • 1,852 Thanks
  • 1,071 posts
Posted July 02, 2015 - 09:14 PM
That's a good tip, Makes sense on all levels. Thanks
  • farmer john and alec have said thanks
#3 larrybl OFFLINE
    Texas Member
  • Site Supporter
  • 7,095 Thanks
  • 4,449 posts
Posted July 02, 2015 - 09:48 PM
A trick I found when masking gasket areas like oil pan or intake is to mask over the gasket area with a good painters masking tape and tap the edges with a rubber mallet and use an exactor knife where the mallet can't get around the gasket edges. Makes for a clean gasket area after painting.
I'll add the Tinfoil trick to my painting tool box. Thanks!
Edited by larrybl, July 02, 2015 - 09:50 PM.
  • olcowhand, Alc, KennyP and 5 others have said thanks
  • 5,418 Thanks
  • 4,703 posts
Posted July 03, 2015 - 07:27 AM
Thanks for the tip
A fellow years ago would smear grease on parts he didn't want to get paint on.
#5 Bmerf OFFLINE
  • 1,796 Thanks
  • 1,466 posts
Posted July 03, 2015 - 08:19 AM
Here's another tip that worked for me:
Years ago I found a sliding window for the back of my truck. The frame of the window needed to be painted to freshen it up before installation. I took liquid dish washing soap and smeared it over all the glass. Spray painted the frame and let sit for a day or two. Broke out the garden hose and rinsed the soap and overspray off. Worked like a charm and saved me from a lot of masking.
  • Alc and CRFarnsworth have said thanks
#6 Jazz ONLINE
  • 2,446 Thanks
  • 1,468 posts
Posted July 03, 2015 - 01:57 PM
That is a good idea. Reminds how much i dislike masking. I painted numerous cars for friends and family for a jug but they had to do all the prep work including masking....this truck was painted with Restoration Shop single stage,,excellent product for $150 kit.. great gloss and very durable
Edited by Jazz, July 03, 2015 - 02:01 PM.
  • Alc, Bmerf and alec have said thanks
  • 495 Thanks
  • 529 posts
Posted July 06, 2015 - 02:44 AM
There is a spray soap on the market for about 20 years now, spray it right out of your regular paint gun. It drys in a couple a minutes ,and when your done just rinse it off with water.
  • Alc and Bmerf have said thanks
