O-scale factory-6
8 replies to this topic
#1 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,867 Thanks
  • 1,850 posts
Posted April 02, 2011 - 06:27 PM
To finish of the rear loading dock, I built a overhanging roof for it.
It is supported by steel beams and by bracing rods that are bolted to the side of the factory.
A concrete loading dock and two sliding doors are added to the side of the factory.
A overhanging roof covers one of the sliding doors.
The other sliding door is going to have a bridge crane mounted over it.
The beam for the bridge crane is made out of a wood I-beam.
It is glued into a potmetal piece that I found in my junk drawer.
This end will mount to the side of the factory.
This is the start of the support for the other end of the beam.
The beam is mounted on the end support and I'm starting to add structural supports.
The base has two holes drilled for locator pins on the support base and the side wall has a hole for a locator pin on the beam.
The potmetal piece already has a locator pin on it and I put two dowel pins in the base.
This way, the bridge crane is held in place by the locator pins and doesn't have to be glued down.
This crane will be over the rail siding.
I still have to make the crane hoist itself.
Here's the finished bridge crane boom mounted in place.
#2 Bolens 1000 ONLINE
  • 14,902 Thanks
  • 18,101 posts
Posted April 02, 2011 - 07:40 PM
NICE!!! :dancingbanana:
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 03, 2011 - 12:18 AM
As always, excellent work, cant wait to see more.
#4 mjodrey OFFLINE
Posted April 03, 2011 - 04:24 AM
As always Ray,your builds never cease to amaze me. Keep up the great work,as I know you will.
#5 KennyP ONLINE
  • 37,439 Thanks
  • 45,468 posts
Posted April 03, 2011 - 05:29 AM
Looking good, Ray.
#6 tractormike OFFLINE
tractormike
  • 166 Thanks
  • 1,488 posts
Posted April 03, 2011 - 05:47 AM
Ray, once again you have done an excellent job! I am looking forward to more of your train layout pictures. Awesome work. :thumbs::thumbs:
#7 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted April 03, 2011 - 09:18 AM
Nice work Ray, your factory employees will enjoy the overhead lift instead of O scale manpower to move the equipment off and on the rail cars.....:smilewink:
#8 daytime dave ONLINE
  • 4,784 Thanks
  • 6,523 posts
Posted April 03, 2011 - 10:03 AM
Fantastic Ray, just fantastic. Keep it coming.
#9 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted April 03, 2011 - 11:17 AM
WOW, great job Ray.
